B18C Conrod bearing part number HELP
Old Apr 30, 2012 | 03:35 PM
oldspriteguy's Avatar
Default B18C Conrod bearing part number HELP
I am re-conditioning a B18C ser#1008728 engine. I mistakenly thought that since the main bearing's were the same size as the B16 I have a parts list for ,the rods would be the same. WRONG! The bearing for the B16 part #13213-P30-004 ( Brown) is 19mm wide and the bearing I need for the B18 is 17mm wide.Who knew! Anyway if someone has the correct part numbers for Brown and for Green rod bearings,I would be very grateful.
Old Apr 30, 2012 | 04:28 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: B18C Conrod bearing part number HELP
Who knew? I thought it was common knowledge. Heck even back in the day "omniman" made a DVD on a 200whp N/A B16 and one of his tricks to "free up HP" was to use the narrower rod bearings. Anyhow, this information is easily searchable - rather than give you the part numbers wanted why not all of them just in case? Eat your heart out son!
http://www.acuraautomotiveparts.org/...s=&view=normal
Old Apr 30, 2012 | 05:06 PM
Thanks Neva eva thats exactly what i needed! you are a great help.
yellovic
Transmission & Drivetrain
Jul 23, 2009 08:37 PM
yellovic
Jul 21, 2009 12:46 PM
jdmhatch94
May 20, 2003 08:02 PM
Turbo00
Jan 12, 2002 03:14 PM
