Couple questions about tuning an 04 SI w/ k24 block
Hey guys, I have a few quick questions about tuning with the KPRO with this car. As far as I know, its stock internals.
Relevant Mods:
Header, Full exhaust
Intake
KPRO
NGK Plugs at .044
1: What should the gap be for this set-up?
2: Is there a base tune that I can get from somewhere that suits this motor more then the base tune?
3: How accurate is the factory wideband? Is this something that I can reliably tune with, or should I run my Zeitronix?
4: The KPRO is reading some knock. How do I know weather this knock is LT or ST?
Relevant Mods:
Intake
KPRO
NGK Plugs at .044
1- you dont gap irridium plugs.
2- upload the k20a2 base map and check afr,if its within the limits then its fine.
3- oem wideband is good enough,both aftermarket and oem are made by bosch i think.
4- give some fuel where its knocking,problem solved
B18C
Oct 23, 2001 03:45 AM
