steering knuckle
Old Apr 30, 2012 | 06:22 AM
jim109's Avatar
Default steering knuckle
i am having trouble locating a steering knuckle for a 2002 accord ex 6 cyl.
IS IT HARD TO REPLACE?
Old Apr 30, 2012 | 07:01 AM
GhostAccord's Avatar
Default Re: steering knuckle
Personally I find them fairly easy to replace. Really depends on whether or not you have the right tools for the job and on your own level of mechanical know-how.
If you can't find one in a junk yard you will have to see if they can do a parts search for you. Some times the can bring one in from somewhere else. Or you could buy one from an online parts retailer such as Honda Parts Deals.com
Old Apr 30, 2012 | 11:17 AM
jim109's Avatar
Thanks Ghost I found knuckle for 2002 accord ex and it comes with lower ball joint already pressed in should make it easier to do . I wonnt have to remove bearing will i? thanks again for your help.jim
Old Apr 30, 2012 | 02:08 PM
If your new knuckle comes with a hub and bearing then you won't have to remove it. If it doesn't then you will have to remove the one from your current knuckle and put it in your new one or buy a new hub and bearing assembly.
Old May 1, 2012 | 01:46 AM
1991EX's Avatar
Just rebuilt my front end and would only want to do it once. If you are going to change the knuckle you will be separating the upper ball joint and tie rod ends also. Just my opinion, but for roughly $100-$150.00 more you could replace the upper arm and ball joint (comes as one), tie rod end and install a brand new Timken bearing.
jfirusta
Suspension & Brakes
Nov 2, 2014 10:28 PM
Maverickz
11
Apr 14, 2012 02:38 PM
ukrainianstyle
Oct 9, 2008 06:18 AM
tico
Mar 7, 2008 09:58 PM
flyinga
Oct 30, 2004 08:14 AM
