Running a vacuum block wondering I should T the ebc
Old Apr 30, 2012 | 03:18 AM
justYncredible's Avatar
It's wU to the sOLdiEr!
Default Running a vacuum block wondering I should T the ebc
I see a lot of people T off the wastegate to the ebc. I'm wondering if I should do the same or just run all my vacuum off a central location, the main reason why I have the block.
Old Apr 30, 2012 | 05:08 AM
TheShodan's Avatar
Moderator
Default Re: Running a vacuum block wondering I should T the ebc
Use the central location if possible, please for your EBC. You want the strongest signal possible.
Old Apr 30, 2012 | 05:27 AM
Turbo-LS's Avatar
Agree with Mac strongest signal as possible for the EBC. I personally line everything to be independent. But central works too it's just preference.
Old Apr 30, 2012 | 08:05 AM
That's exactly what I wanted to hear
Now I need to find out why my accessory terminal under the dash isnt giving out any voltage. It's really odd if you ask me
I know it's an off topic question but what fuse, if any, is tied into it?
I have a 95 teg btw
Old Apr 30, 2012 | 08:29 AM
zerovandez's Avatar
Which accessory terminal? There has to be a dozen down there. Make sure you are testing it with a good ground.
Old Apr 30, 2012 | 08:46 AM
It's the terminal above the fuses
I have a good ground just not getting anything on my digital meter. It's really weird
I'll try something else today. Even if I hook up a light it still doesn't work.
Old Apr 30, 2012 | 04:35 PM
zerovandez's Avatar
Trace it back to the key solenoid. Honda's typically have 2Accy leads. I forget the colors but you can find it labeled IG2, and ACCY on the key solenoid, you might have it confused with IG1.
Old May 1, 2012 | 03:33 AM
fcluddington's Avatar
I T'd off the turbo outlet to the EBC and it has worked really well without a assload of vaccum lines running all over the place. My MAC valve is really close to the WG and they can take a lot more heat than I would of thought
Old May 1, 2012 | 09:30 AM
Muckman's Avatar
Moderator in Chief
I dont run a vac block anymore but when I did I ran it off the brake booster hose.
Your EBC and Wastegate sources should be right from the compressor if you have a fitting there.
nicole_
Dec 30, 2014 05:15 AM
RPMvulocity
Dec 28, 2012 09:42 AM
that-guy
Engine Management and Tuning
Jun 9, 2011 06:24 AM
Silvertc
Apr 16, 2009 09:18 AM
watacivic
Audio / Security / Video
May 19, 2007 12:37 PM
