Complete B-series engine & turbo set up
I'm testing the waters on my B-series engine and turbo setup. I might part out but for now I''m listing it all together.
Motor: SOLD
Fully rebuilt B18b1, bored to 81.5mm and honed, a little over 3k miles on it.
Wiseco 9.8:1 81.5mm pistons
Eagle H-beam rods (came with arp rod bolts)
ACL Race Rod and Main bearins
Clevite Thrust bearing
ARP head studs
Polished ls Crank
Precision 880cc Injectors
Omni 70mm TB
Bored oem Intake Manifold (matched to TB)
PWJDM magnetic drain plug
New distributor
Drop Engineering Mounts
New Gates Racing Timing belt
Competition stage 3 6puck clutch
Hondata 4 bar map sensor
Hondata thermal intake manifold gasket
Blox velocity stack with filter
Tapped oil pan
Koyo Racing half core radiator
Turbo set up:
Custom Ramhorn manifold SOLD
Rebuilt Garret t3/t4 hybrid A/R .50 turbo with a stage 3 compressor wheel
Hondata boost control solenoid SOLD
HKS SSQV 3 BOV SOLD
TiAL 38mm wastegate SOLD
Custom heat wrapped dump tube SOLD and downpipe
Huge intercooler SOLD
Custom intercooler piping SOLD
Will also come with a good LS transmission (SOLD) and a Hondata s300 chipped p28 ecu (SOLD)
I'm probably forgetting some stuff so check back for updates
I'm asking $4000 obo, this setup could easily make 500hp. The entire setup as barely over 3k miles on it. I've taken my time to piece it together for the last 2 years and build it my self to make sure it was done right.
If its a local pickup ill throw in the custom 3 inch exhaust.
I'm located in Texas but am willing to ship at the buyers expense.
Thanks for looking.
Motor: SOLD
ARP head studs
Polished ls Crank
Omni 70mm TB
New distributor
Tapped oil pan
Turbo set up:
HKS SSQV 3 BOV SOLD
Thanks for looking.
Eagle H-beam rods (come with arp rod bolts)
PM me prices on these ^ and your location. I know your in T.X. but what part?
i have some one interested in the entire engine, ill let you know if it falls through.
bad1_s2k
Jul 13, 2009 06:06 PM
bad1_s2k
Jul 12, 2009 06:08 PM
