Questions about the ECU#: 37820-P29-000 JDM ..!!
Good Evening all
-What is the original type of engine does that ECU goes with?
-What year?
-Which Region?
-For which car?
-What's the differences between the P29-000 and the P29-T00?
And again/most importantly :
((-What's the correct engine for that ECU..?!))
Knowing that it's an OBD1 ECU judging from the photo.
please provide us with informations as much as possible, so everyone including me can gain more knowledge about our Honda's
Thanks.
-What year?
-Which Region?
-For which car?
Thanks.
I have found a couple of a useful information about the two rarest ECU's the :
37820-P29-000 and the 37820-P29-900
for the P29-000 :
Complectation: SI 20TH ANNIVER.
Frame name: E-EG5
Engine: ZC
Transmission: MT
Doors number: 3
Options: air bag, driver, auto air conditioner, sun roof, power winder, power suite, ABS, LSD
and for the P29-900 :
Complectation: SI
Frame name: E-EG5
Engine: ZC
Transmission: AT
Doors number: 3
Options: optional air conditioner, power suite
that is all i know for now
I have a question I wanted to ask you all about
Is it possible that the P29-000 ECU can run on different types of engines and function properly?
for example from a Japanese ZC engine to a European ZC engine??
for the P29-000 :
Frame name: E-EG5
Engine: ZC
Transmission: MT
Doors number: 3
Complectation: SI
Frame name: E-EG5
Engine: ZC
Transmission: AT
Doors number: 3
about that ecu, i have a 37820-p29-t00 inside of my honda del sol. i am from lebanon so my honda is a jdm and it came with the d16a9. my ecu is not working and my car isn't turning on
Take the lid off, and look for the board identification on the corner of the board. Use that to google repair options.
Theres only a handful of board variants, its the components on it that vary per different features. Basic function like fuel pump circuit will all be the same.
Capacitors may need change, #1 most common issue.
https://www.homemadeturbo.com/engine...da-ecus-98549/
