Part out: 1994 Acura Integra 2dr 5spd
I parted out a 1994 Acura Integra LS Coupe with a b18b1 5speed. Below are the ONLY parts I have left. All prices are best offer and do NOT include shipping or PayPal fees. Text iss the best way to get ahold of me: 513-253-6660.
AC Condenser - $***SOLD LOCALLY***
REar speaker pods - sold as pair only - $10
Driver power window motor - $25
Passenger window motor - $25
Driver and Passenger front seat belts; black/gray interior - $10 ea, $15 for the pair
Clutch master cylinder - $15
CRuise control brain box - $10
Underdash fuse box with fuses/relays - $10
Tranny Mount - $8
Positive/Negative battery cables - $5
CLutch Slave - $20
ARmrest, ***SOLD LOCALLY***
Cruise control box for the engine bay - $15
ABS Brain/ECM - $15
Front Strut Forks; won't separate - $20
E-Brake handle (black) - ***SOLD D-SERIES MEMBER***
REar lower LCA with endlinks. Will need new bushings; won't separate ***SOLD TO D-SERIES MEMBER***
Rear strut top hats; won't separate - $10
Hood latch and cable; won't separate - $20
Driver window - $20
Blower Motor - $15
E-brake cables (came from rear disc if it matters); won't separate - ***SOLD TO D-SERIES MEMBER***
Driver side A-pillar; gray - $20
Gas door; dark gray, no rust or major scratches - $10
5speed pedal set; won't separate - $40
B18b1 AC BRacket ***SOLD TO D-SERIES MEMBER***
Engine Bay fuse box with fuses/relays - $10
(NOTE: Dual bend shifter sold 5/24 to HT member)
- Driver and Passenger sun visors. Gray. Dirty but should clean up fine. Will not separate - $15
- AC/Heat controls. Worked fine when removed - $30
- Ashtray/Lighter with harness ***SOLD D-SERIES MEMBER***
- Headlight arm switch - $10
- Driver window, mirror and door lock control. All worked fine when pulled - ***SOLD TO D-SERIES MEMBER***
- ABS relay (harness cut, but left about 6" of wire) - $5
- Rear View Mirror - ***SOLD TO D-SERIES MEMBER***
- Cruise button - $5
- Dimmer Switch - $5
- Passenger window control - $10
- Original Owners manual - $10
- MAin Relay - $20
- Driver and Passenger door handles - $8 each, $10 for pair
- Dome Light - $5
b18b1 motor. ***SOLD LOCALLY***
The items below are ones that I don't have pictures of but can get if you really need them.
- Rear trunk carpet. Black. No rips or tears, but it's pretty dirty and will need a good shampooing. No guarantee all the dirt will come out, but it's for a trunk - $20
- Driver and PAssenger door sills. Black. Will not spearate - $15
- Front subframe with front sway bar and LCAs. LCAs will need new bushings. Will NOT ship - $50
- Plastic rear panels with strut mount covers. Black and in great shape. Will ship, but not sure it will be worth it - $50
- Coupe side Skirts. Black and un-painted. Will not separate. ***SOLD LOCALLY***
- Front splash/wind guard - $20
- Steering column clam shell. Black and in good shape with no cracks - $15
- Power Steering rack. ***SOLD TO D-SERIES MEMBER***
TEXT ME ANY OFFERS/QUESTIONS: 513 253 6660
I don't answer phone numbers I don't recognize. Please only text me.
All parts are also available for pickup on the eastside of Cincinnati or southside of Dayton (I work m-f, 8a-5p, so ONLY then works)
Tranny Mount - $8
CLutch Slave - $20
ABS Brain/ECM - $15
Driver window - $20
Blower Motor - $15
- MAin Relay - $20
- Dome Light - $5
All prices are BEST OFFER and only becuase I need to list prices. I am open to offers on everything. Send them my way. I need the space in my driveway!
Geay exterior with a black hatch/spoiler (clearcoat is pealing on the hatch; spoiler is good though). But aside from the pass door, there's no panels worth taking.
Interior is black/gray. Aside from most of the panels, the big stuff is gone. Shoot me a text with what you are looking for: 513-253-6660
REar seat belts sold, as well to a fellow HT'er (hopefully he'll post a vouch as I didn't get his screen name)
Driver knee bolster, turn signals and metal garnish above the rear bumper sold locally tonight.
Taking offers on everything else
Both front fender liners, driver's side outside door handle and power locks brain box all sold locally last night.
I'm open to offers on everything. Don't be shy to text me with what you need. I could use the space, so resonable offers being taken!
how much for the long block now that im and what not is sold?.. i also dont need the ex mani, alt, or brackets or anything just the running longblock(oil pan to vc with the oil pump, water pump belt etc . with water pipe. thanks.
AC Hardlines sold locally.
Shell picked up by the junkers today!
Sure do... includes the master cylinder with it. $40 plus shipping. Text me with your zip and I'll get you a shipping quote (won't fit in a USPS flat rate). MY number is in the first post
Sorry, I don't
Sold to a D-Series Memeber
Yup... worked fine. $25 plus shipping. Send me a text with your zip. I don't think it will fit in a large USPS flat rate.
And sorry for the late replies... I've been busy with a house remodel. I've updated the first post with pictures, prices and more parts.
Sorry, I don't
