obd0 to obd1 dizzy question
Old Apr 28, 2012 | 11:54 AM
m3kid's Avatar
Default obd0 to obd1 dizzy question
alright so im doing the dpfi to mpfi obd1 swap so my question is when i im converting the dizzy wires can i make my own jumper harness without using the plugs and just straight solder them to each wire? or do i have to use the plugs?
Old Apr 28, 2012 | 02:12 PM
civickiller's Avatar
Default Re: obd0 to obd1 dizzy question
you can solder them but twist each wire and make sure it works good first before soldering.
i did the same swap dpfi-mpfi, obd0-obd1. but i converted my chassis harness to a obd2a plug. 6 months i got a code 8, needing a dizzy change. a year later got a code 9, needing another dizzy change. im glad i swapped my chassis harness so dizzy's were direct swap
not saying youre going to have the same bad luck i was having, just saying im glad i took the time and did it right
Old Apr 28, 2012 | 05:09 PM
m3kid's Avatar
yea alright this is just temporary until i can find si dizzy connectors there really not common but thanks
Old Apr 28, 2012 | 05:18 PM
m3kid's Avatar
btw all those wires from the harness will go to the obd1 female plug so that what i was asking but thanks
zapzach
19
Feb 24, 2012 10:35 AM
punkracer
Aug 9, 2011 03:36 AM
crx_si-r
Feb 26, 2010 07:48 AM
pokmijn
Aug 2, 2008 11:15 AM
jtroy917
Jun 3, 2007 02:54 PM
