wilwood brake ms problems
put on my wilwood brake master over the winter and now the brakes keep dragging after i press in the pedal. like it isn't releasing pressure off the caliper. took the rod off the pedal inside and adjusted it and it released it but when i took it out to track it did the same thing. can't even push the car or spin the wheel when it's up in the air after this. it has all new stainless braided line from the ms to the front wheels. I am just using front brakes no prop valve just a "t" off ms to the front brakes. same size line to both sides. any help or ideas appreciated.
im having the exact same problem... i was using my stock proportion valve to use all 4 breaks and it was locking all my tires up slowly after i hit the breaks once...i thought it was due to using the proportion valve so i took it off and just ran a T to the two front brakes but its still does it ... i have to go to the ms and lossen up the line so that the breaks will release ...
Last Kens custom kit I installed, the rod on the MC was too long and even turned all the way down it dragged the brakes like you mentioned. We ended up cutting some of the threaded section off the rod and moving the brake switch slightly back to get it to work right.
byronl
Jan 22, 2008 12:55 PM
CobraCanuk
Nov 30, 2004 08:05 AM
hahahahhah
Sep 9, 2004 05:19 PM
