Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
2nd Gear Slipping - Giving Jerks
Old Apr 28, 2012 | 05:09 AM
nj_nj's Avatar
Default 2nd Gear Slipping - Giving Jerks
HI...
Please help me with the following case.
I own a Acura 3.2 CL - Automatic Transmission which I bought as a 3rd Owner. I saw that this car was recalled in 2004 for 2nd Gear Transmission Issue.
Problem is: Now I am facing an issue while the car is in 2nd gear. It gives jerks & doesn't move to 3rd gear.... Also engine makes noise while it gives jerks & "Check Engine" light starts blinking on panel.
If somehow it moves to 3rd gear; than it works perfectly fine...
I got it checked at a nearby Honda dealer & they told that the error code refers to Misfire due to "Throttle Position Sensor" (TPS) which has to be replaced. But no ACURA dealer in nearby area had that sensor.. (out of stock) so it can be changed next week only.
I have 2 questions:
1. Is it safe to drive the car in such situation?
2. Will new TPS solve issue or its a Transmission issue (Dealers are making fool & seeking money)
Thanks!!!
Old Apr 29, 2012 | 04:29 PM
nj_nj's Avatar
Default Re: 2nd Gear Slipping - Giving Jerks
I checked the error codes again today... they are P1399,
P0300, P0301 & P0305. All these error code doesn't indicate
any tranny failure.
Does transmission failure show any error code or they are
just experienced; like jerk or gear slippage?
Old Apr 30, 2012 | 05:42 AM
Gt limited(jdm approved)'s Avatar
tranny needs to be rebuilt the earlier the better because when the vehicle immobilized the transmission harder to repair. Maybe the filter needs changing too
Old May 12, 2012 | 07:30 PM
klectic's Avatar
Sounds like your tranny is going. I wouldn't drive it, just get it back up and running soon. When mine went out I was stuck on 2nd and couldn't engage 3rd. Luckily I was driving to the shop to drop it off to get it rebuilt. Good luck.. I know its a bitch.
Ali F. Ahmad
Honda Civic (2006 - 2015)
Aug 6, 2017 01:50 AM
Kevykev
Acura TSX
Jul 13, 2008 09:33 AM
ROCcityRSX_S
Dec 10, 2004 01:35 PM
f1 vtec
Jun 9, 2004 09:17 AM
Iggy_Type_R
Aug 7, 2003 01:58 PM
