[NJ] LSV PART OUT
vin for motor 1203502
vin for trans 1071480
im selling my ls block needs pistons and bore
comes with:
eagle h beam rods
golden eagle headstuds
acl race bearings
oem type r oil pump
type r water pump
gates timing belt
blackworks blockguard
tapped oil pan for turbo
f1 stage 3 clutch set up clutch isnt even fully broken in
1000 obo dont low ball me theres more money in parts than what im asking for ..
motor was freshly rebuilt but used the wrong heat range and destroyed my pistons u can bore it to 81.5 and wont have a problem not badly damaged all you need is a fresh bore and pistons
selling my b16 head
type r intake manifold
68mm str throttle body
blackworks cam seal
all new oem valve stem seals and cam seals
comes with gsr cams and b16 cams skunk2 cam gears
freshly milled used for less than 50 miles
already tapped for lsv and have lsv kit for it used but i have it
850 obo
also selling my turbo kit set up that was on this motor
cxracing 50 trim turbo
mini ramhorn manifold
rc 1200injectors
turbonetics evolution wastgate
greddy type s bov
31x3 intercooler and piping
oil return and oil feed line
dumptube and 3"downpipe
p06 ecu chipped tune for this set upo made 330 hp and 248 tq on this set up on crome pro
eberything u need is there
1300obo
gsr trans 400 bucks no grinds or pop outs
txt for pics 2014679221
comes with:
eagle h beam rods
acl race bearings
oem type r oil pump
type r water pump
gates timing belt
selling my b16 head
blackworks cam seal
850 obo
rc 1200injectors
greddy type s bov
1300obo
Hey I am interested in the turbo but I don't need the injectors. How many miles does it have on it and what PSI did you usually run it at? I'm just about finished building my 2000 outside with a b 16 fully bill and jen and I'm looking for a good solid turbo kit. Everything under the hood is brand new and sparkly clean how did your stuff look?
5th element
Feb 27, 2014 01:09 PM
5th element
Jan 29, 2014 02:09 PM
SoSoxGino
Oct 24, 2004 01:43 AM
