How hard is it to change a thermostat and/or coolant temp. sensor?
Old Oct 12, 2002 | 03:30 PM
VTEC
Guest
Posts: n/a
Default How hard is it to change a thermostat and/or coolant temp. sensor?
My car is overheating...I already put in a brand new radiator after my old one sprung a leak at a track event. A month later, my temp gauge began fluctuating. I wasn't sure if it was a bad thermo, as the upper and lower radiator hoses were the same temperature.
Interestingly, the temp gauge moves up if I close the sunroof on my Civic...
Anyways, I'm pretty sure my fluctuating temperature is from either the temp sensor or thermo. The thermo is the original, 8 years old/165,000miles.
Old Oct 12, 2002 | 04:25 PM
tinkerbell's Avatar
Default Re: How hard is it to change a thermostat and/or coolant temp. sensor? (VTEC)
both pretty easy, you will be playing with coolant though, which is dangerous...
maybe 1-5 hours depending on your skills...
go with teh temp sensor 1st, then the thremostat...
t..
sounds like you also have an interresting wiring setup!?!
Old Oct 13, 2002 | 12:10 AM
salbaje's Avatar
did you bleed the system when you put in the new radiator??
Old Oct 13, 2002 | 02:10 AM
VTEC
Guest
Posts: n/a
Default Re: How hard is it to change a thermostat and/or coolant temp. sensor? (salbaje)
Hmmm...you know what...I can't remember. Should I take the rad cap off, and wait for the bubbles to come out, then add more coolant? Or should I just drain everything off, and add a fresh supply?
Juicebox888
Mar 30, 2019 08:18 AM
JBBNJ609
Honda Civic (2001 - 2005)
Jun 29, 2012 11:07 AM
vodkaTM
Sep 26, 2009 11:43 AM
SPORT INJECTION
Oct 31, 2004 10:36 PM
