11 Inch Prelude brake upgrade CLARIFICATION
Old Apr 27, 2012 | 11:11 AM
LatnKng's Avatar
Default 11 Inch Prelude brake upgrade CLARIFICATION
Ok, so i know that this upgrade question has been asked WAY TOO many times, and i have researched it and even asked questions to no avail...so anyone please clarify for me once and for all.
....ALL this write up on how to do this upgrade, and each one confuses me..maybe im just SSSSLLLLOOOOWWWW...but i'm having a hard time trying understand. Heres my deal...I have a 92 Prelude S..with an H22A, not that it matters i guess, and i'm trying to upgrade my rotors to 11'. I have both 23t caliper brackets off of a 99 Acura CL along with the calipers themselves. My HUBS are stock type S Prelude ones and i'm ABSOLUTELY NOT SURE WHAT HUBS TO USE and WHICH ROTORS will need RE-DRILLING, or even if the 07 MINI COOPER S or REGULAR rotors will fit with no issues...make it SIMPLE for me please ppl..theres alot of OPINIONS out there on how it should be done, but someone break it down..which plenty of you have attempted, and so i say IM SSSLLLOOOWWWW!!! thanks to all of you again for the inputs.
__________________
Old Apr 27, 2012 | 12:35 PM
kyden's Avatar
Default Re: 11 Inch Prelude brake upgrade CLARIFICATION
mini cooper rotors won't work, as they are 4x100.
Old Apr 27, 2012 | 01:24 PM
BergRacing21's Avatar
just buy Si VTEC calipers and rotors...i think they are like 10 3/4" and then you wont have to change anything on the spindle other than that. or do a big brake kit
Old Apr 27, 2012 | 04:18 PM
minilogoguy18's Avatar
^This, there's no reason to go any bigger than the Si VTEC setup unless it's a dedicated track car used for road racing.
Old Apr 27, 2012 | 07:40 PM
LatnKng's Avatar
I've read that the 96 VTEC rotors are 11''..and thats the upgrade i'm trying to go for, but there are lingering questions about the SPINDLE itself and which to use, also about the rotor, that it needed to be RE-drilled.
Old Apr 28, 2012 | 05:06 AM
There's absolutely NO modification if you want to do the Si VTEC rotors other than bending your dust shield back if you don't feel like buying a new one.
Old Apr 28, 2012 | 05:11 AM
LatnKng's Avatar
Ma'an THANK YOU very much...i was actually searching other post or threads that i might have missed on the HUB to use, and finally just understood most of the upgrade threads out there. NONE of them are for PRELUDES, they are all for CIVICS and REX upgrades, and so i couldnt get a def answer, but thank you again, i kinda realized that the PRELUDE hubs should work fine with the bigger SI VTEC rotors on there, just didnt click.
Old Apr 28, 2012 | 05:12 AM
LatnKng's Avatar
I wonder what the specs are on the 92-96 lug pattern, never searched, random question.
Old Apr 28, 2012 | 10:25 AM
Also if you're having trouble finding the larger VTEC front calipers you can use 5g, 5g front brakes are identical to 4g Si VTEC just that the rotors are 5 lug.
Old Apr 28, 2012 | 12:02 PM
apexi_bb6's Avatar
I should have a full set of 5g calipers boxed up somewhere, 150k or so with no issues when removed a few years ago. Pm me if interested and ill look for them. Was saving them for a 5 lug swap that never happened.
Old Apr 29, 2012 | 04:40 PM
92-96 ludes are 4x114.3 lug pattern. But what they're saying is you could still use the 5th Gen CALIPERS and just get the Si VTEC rotors and nothing will have to be modified.
*Read ^that before reading this* now if you wanted to do the whole 5th gen swap you would have to do modification cause you'd be going to a 5 lug pattern on the newer Preludes.
Hope that helps and doesn't confuse you too much haha.
Old Apr 30, 2012 | 07:06 AM
LatnKng's Avatar
It sounds like the 4g Si VTEC / 5g calipers would be the easiest route to take so you wouldnt have to do any mods like shaving the LEGEND or CL calipers to fit the bigger rotors, so i'd def be interested in that 5g calipers.
I will PM if you still got them boxed up.
Old Apr 30, 2012 | 07:09 AM
LatnKng's Avatar
Icon3 Re: 11 Inch Prelude brake upgrade CLARIFICATION
All the info REALLY helped, like you said, the only mods would be if i were to switch to a 5 lug set conversion. And DEF thank you on the lug pattern for the 92-96 ludes, i knew it was diff but wasnt sure of the specs on them, it really helped. Im SET now, THANKS TO ALL AGAIN.
Old Apr 30, 2012 | 09:55 AM
apexi_bb6's Avatar
Ok, Ill try to look for them tonight.
Old May 2, 2012 | 06:35 AM
LatnKng's Avatar
Pm'd
Old May 3, 2012 | 10:28 AM
typemismatch's Avatar
Honda owns me
I did this last year, I used 96 VTEC rotors and calipers not Si, I believe Si meant H23. I got the calipers and brackets off of RockAuto cheap and bought slotted rotors [Centric?? brand] off some website or another. I also upgraded to the Hawk HPS pads at the same time. Not sure if it was the HPS or another pad, I know it was Hawk though.
Old May 3, 2012 | 05:21 PM
yroachy's Avatar
somebody may be able to correct me on this but i was under the impression that the calipers are the same, but the caliper brackets are different.
Old May 3, 2012 | 06:29 PM
i believe the VTEC models are bigger, but Hawkze clarified that the rears are all the same.
Old May 9, 2012 | 05:38 AM
LatnKng's Avatar
I actually just finished doing the change from 92 S rotors to 96 VTEC up front. The calipers are different, 96 are bigger and fit around the 11.3'' rotors fine..i think its 11.3.
Old May 9, 2012 | 05:41 AM
LatnKng's Avatar
Also fellows, THANKS AGAIN for the assists and the info on this upgrade..as i said before i wasnt clear on what to change out at first, but asking questions alwasys helps. The rotors are awesome and look good under 16'' wheels along with the calipers. I will post pics later for thosethat would like to see or even attempt the change. THANK YOU ALL AGAIN.
Old Feb 25, 2013 | 11:01 AM
Ac3shi6h's Avatar
The 1992 Prelude (SI, 2.3l) has a 4x100 lugnut pattern.. I know.. I just upgraded my wheels!!
Old Feb 25, 2013 | 03:07 PM
Apex1972's Avatar
LOL
Old Feb 27, 2013 | 07:49 AM
yroachy's Avatar
Weird, mines has 4x114...
Old Mar 1, 2013 | 01:15 AM
LatnKng's Avatar
That's odd, BCus mine is a 92 S and the pattern is 4x114, which all 4th gens should be, unless yours was changed out!
gsrious
Suspension & Brakes
28
Jun 1, 2021 07:16 AM
angeloserio
Jun 8, 2010 12:16 PM
tooth_dr
Suspension & Brakes
May 3, 2009 12:25 AM
90jdmda90
May 14, 2008 06:19 PM
EK4door
28
May 17, 2004 07:45 PM
