AEM EMS h22a7 N/a cold start issue.... Please help
Hello all,
I have just bought a pnp AEM EMS series 2
I have been rather enjoying making the car run on the little knowledge i have.
I have been able to get a lot going for me, good idle, acel deacel is stable, no cut off, 14.5 afr on idle and running tachmeter to name a few.
Though the cold start is killing me, i have been messing it for hours and she wont conk up exactly in time. Its a minimum of 2 cranks to 5-6 cranks for it to get going. Hitting the throttle does help at times. The fuel pressure gauge shows 2 bar of fuel when the pump prime is over.
I have been tweaking the calibration but just cant get it right. If one of your can be so kind as to check my calibration or load yours so i can get a idea.
Spec of my engine is :
H22a7 total stock, no changes at all apart from the management.
Any pointers on a smooth start are most welcome.
Other infor : Start Sync goes on, battery voltage between 13.8 to 9 while cranking, below 9 no crank, crank advance 7.3 degree
my cal is below:
http://www.2shared.com/file/mJ0IvXmv...etonation.html
Regards
my cal is below:
Regards
TurboIntegra
Engine Management and Tuning
Feb 26, 2009 04:43 PM
