Por15 - Sandable? Apply directly over bare metal?
Old Apr 26, 2012 | 01:59 PM
Vagitarian's Avatar
Default Por15 - Sandable? Apply directly over bare metal?
On some spots in my engine bay and underbody where I have some surface rust.
Do you simply sand them to bare clean metal, brush on Por-15, and call it a day?
Or is there some sealers/ sanding/ better way to approach it?
My battery tray and engine mount look like crap
Old Apr 26, 2012 | 05:48 PM
habanerored06si's Avatar
Default Re: Por15 - Sandable? Apply directly over bare metal?
Follow their system.
They suggest using Marine Clean (Degreaser) before applying their anti rust paint for maximum bond. They also have a Silver Topcoat which has UV protection along with other strengthening properties.
I'm going all POR-15 out on my Del Sol.
Old Apr 26, 2012 | 07:04 PM
Vagitarian's Avatar
Well I only plan to use it on suspension and underbody parts so I'll probably be fine without the UV topcoat, if they made the UV topcoat in black I may try it
I was more curious if you could sand it, and if ONLY por-15 had to be applied right bare sheet metal or cleaned/wire brushed metal parts... or if it was good/bad to seal or prime or anything first
Old Apr 27, 2012 | 07:26 PM
Why could you not sand it?
It states for maximum hold to use on cleaned/bare metal. BUT it also says you can apply directly on rust.
Prime is last.
Old Apr 27, 2012 | 11:16 PM
gorillafart's Avatar
Old Apr 29, 2012 | 05:47 AM
Hawkze_2.3's Avatar
POR15 will not stick to clean bare metal. You WANT minimal surface rust for proper adhesion.
I purposely rust my parts before POR:
Old Apr 29, 2012 | 09:12 AM
siblues's Avatar
Hey Hwkze do you have any parts that have had por on them for a few years.I know it looks great when its freshly applied but how well does it stand up over time.
Old Apr 29, 2012 | 02:10 PM
Vagitarian's Avatar
Overtimne is what im concerned with to
I can get chassis saver locally for half the cost
So that may be an option to
Old Apr 29, 2012 | 05:34 PM
Hawkze_2.3's Avatar
POR15 looks the same as it did the day you applied it as long is UV light doesn't hit it. That's the only weakness really (it will turn to powder if it's under the sun for long enough )...I mean rocks and metal stuff can still chip it if hit hard enough, but for longevity nothing beats POR15. My Prelude and CRV suspensions have been done for 1-2 years now and they still look the same. It didn't hold up well on a muffler I did, but that is a heat issue.
It's a moisture-cure product, meaning H2O actually causes it to harden and cure, so you don't have chances of moisture bleeding under and rusting like most paints.
The only thing I can think of that might cause a change is if you clean it with something abrasive like a towel or scrub pad of some kind. That could scratch it and leave swirl marks.
b16bri
Paint and Body
May 30, 2012 06:51 PM
pjr710
Paint and Body
11
Jul 24, 2008 06:49 PM
m1ndless
Oct 31, 2006 12:00 AM
Six2Six
11
Mar 26, 2004 03:54 PM
wm5holla
Feb 4, 2003 06:26 PM
