yellow maintenance light is on?
Old Apr 26, 2012 | 12:49 PM
hughgogh's Avatar
Default yellow maintenance light is on?
i just topped off my oil with syntec blend 5w30, and my maintenance light came on? anybody know what that means- also im about to do the clutch anybody know of a good brand to go with and some how to manuals-98 lude sh
Old Apr 26, 2012 | 01:13 PM
hughgogh's Avatar
Default Re: yellow maintenance light is on?
155,000 miles, vtec, standard, also feels like its running boggy?
Old Apr 26, 2012 | 03:51 PM
TheJGB3's Avatar
The maintenance required square in the cluster is for reminding you to change your oil
It is green after being reset by putting in your ignition key when changing the oil
7500mi. after being reset it changes to amber if it has not been reset with the key (7500mi is Honda's recommendation for the oil change interval)
at 10,000mi. after being reset it changes to red
This indicator is only to remind you to change your oil, and is connected to the odometer only nothing else
Old Apr 26, 2012 | 07:51 PM
Folfin's Avatar
And by putting in your key he means the slot right next to the little square light. Though I don't think you need your key.. as far as I know anything works so long as you press it down enough.
As far as the clutch, do a search on YouTube or really anywhere but be sure to give yourself plenty of time to do it. It's not a fun job at all doing it for the first time (or any time after that). I'd say use oem materials because if you go for one with one aftermarket that's more grabby than you need its going to be terrible to drive. MAKE SURE YOU GET THE FLYWHEEL RESURFACED WHEN YOU PUT IN A NEW CLUTCH. Ive seen good clutches go bad quick without that.
Folfin's Avatar
Also what do you mean by boggy?
Old Apr 26, 2012 | 11:01 PM
jdm_rb20's Avatar
He probably needs a whole tune-up if he doesn't even know about the maintenance light (no offense). Cars run a whole lot better when they are treated right. If you just bought it or have never done the following, I suggest: oil change, new sparkplugs/wires, fuel injection cleaner, new air filter....if it still feels boggy after that $100 is put into it (BASIC maintenance for that mileage), then I would check for codes.
(also, whenever you get another $100 or so, if it is a little bit tappity/chattery at the top end of the engine, you are probably due for a valve-lash adjustment.)
btw, I suggest the tuneup before the code-check because if you are feeling it boggy and feeling the clutch slip, I assume that you are "getting into the gas pedal". If you are gonna run it hard, you need to treat it with some TLC. lay off the pedal until you know the car is atleast equipped with the tune-up.
Old Apr 27, 2012 | 12:16 AM
hughgogh's Avatar
this is my first honda, i did the brakes and oil about 4 months ago, ive noticed that it burns oil-about a quart a week, i reallly want to learn as much as i can about this car because i love driving it and i totally understand about the TLC- but even when i dont run it hard i can feel the clutch grinding through the stick shift at 4500 rpm, and that doesnt feel right, anybody know what a shop would charge for a clutch job?
Old Apr 27, 2012 | 12:20 AM
hughgogh's Avatar
when i shift and accelerate, it makes a muffled sound/kind of like something is clogging the air flow? does that make sense, but its weird some days it will run torqy as hell and others it runs like that...
Old Apr 27, 2012 | 12:28 AM
hughgogh's Avatar
also it came with an injen cold air intake system? would that have anything to do with the way its running?
Old Apr 27, 2012 | 04:19 AM
jdm_rb20's Avatar
have a knowledgeable person drive it. Sometimes that grinding is because the synchros wear out in the transmission. I don't want you to pay for a clutch job if that isn't the problem.
The muffled sound....hmmm..guess I would have to be there. If you are taking care of the basic maintenance, you can always check the timing and make sure it's not off by a degree. Timing being off will cause a bogging/muffled sound bc the inflow>>outflow timing is not at peak performance.
Old Apr 27, 2012 | 04:31 AM
Hawkze_2.3's Avatar
Intakes don't do anything either way, so you don't have to worry about that.
Old Apr 27, 2012 | 10:50 AM
hughgogh's Avatar
helpful stuff thanx doods
Old Apr 30, 2012 | 12:58 PM
TayLude's Avatar
The Light goes on after so many miles. And If it's boggy It's time for a tune up
Old Apr 30, 2012 | 05:51 PM
jdm_rb20's Avatar
.....And the last horse finally crosses the line!! lol j/k with ya, Tay.
2008civic
Honda Civic (2006 - 2015)
Oct 13, 2008 02:46 PM
bausts
Mar 13, 2007 10:30 AM
blackriceman
Mar 29, 2004 08:33 PM
kseriesDC5
Mar 26, 2004 07:32 AM
:jdmshmaydm:
Jun 19, 2003 06:44 AM
