h22 to f22 trani swap.
Old Apr 26, 2012 | 10:31 AM
flipmoderacing1's Avatar
Icon2 h22 to f22 trani swap.
I have a H22 w/ a bad trani. I have an F series trani laying around and was wondering if it was possible to use it on the H22? I know you can swap heads between the two so I figured it might work. Any help would b greatly appreciated.
Old May 2, 2012 | 03:35 PM
lude72's Avatar
Default Re: h22 to f22 trani swap.
it will work the gearing is a little longer but it will work
Old May 2, 2012 | 03:37 PM
Tw34k's Avatar
Why is your avatar a picture of a VAFC, those things are like HIV for Hondas.
Yes, H and F trannys are interchangeable.
Old May 2, 2012 | 06:42 PM
Hidenplanvew's Avatar
It will be alittle slower but It will work.. might as well do a clutch and rear main seal as they are easy to do while the trans is out
Old May 3, 2012 | 04:29 AM
jdm_rb20's Avatar
I am running h22 with f22 trans. Works great for me. Think positive, you go a little longer without having to shift. I feel like it decreases on mis-shifts also since you aren't shifting as quickly.
--TJ
virgstyle
21
Aug 8, 2006 02:21 AM
spooneg8
Mar 26, 2006 08:59 PM
92Preluda
Jun 28, 2004 08:52 PM
