94 civic ex auto harness for gsr swap!!!
Old Apr 25, 2012 | 07:12 PM
Dan_EJ1's Avatar
Default 94 civic ex auto harness for gsr swap!!!
What's up HT,
I'm confused about something...I was doing research.and now I'm more confused...ok I have a 94 civic ex and it was a automatic ...I did the 5 speed conversion already and now I just recently bought a gsr swap...my question is can I use my ex auto engine harness for the gsr swap...I have a friend that said that its a headache so I did some research and some say I can use and some say something about rewire pins or something...is the harness plug and play or do I have to do modication to work? Or should I just get a integration harness.... can someone help me I greatly appreciated...thanks
Old Apr 25, 2012 | 07:59 PM
egsleepercivic's Avatar
Default Re: 94 civic ex auto harness for gsr swap!!!
you will need to add the wires for the knock and the IAB on the gsr, and you will need to seperate the O2 wires from the loom and reroute to the new location of the O2 sensor location which is closer to the cat,
this will show you what to do with the wires at the ECU
http://www.ff-squad.com/tech/wiring/wiring.92-95.jpg
Old Apr 25, 2012 | 08:12 PM
Dan_EJ1's Avatar
Does that applies to my automatic harness? Also my gsr comes with skunk2 intake Mani....I don't think I don't have to worry about the IAB...is that correct?
Old Apr 25, 2012 | 08:25 PM
if you are not using the stock intake manifold you don't have to worry about IAB, if you have already converted to 5 speed for the d series everything should be the same for the B, but you may wanna wait for someone who has expierence with automatic harness
Old Apr 25, 2012 | 08:37 PM
Dan_EJ1's Avatar
Well I think its a plug and play since it's already running...I am aware of 2 plugs that wont be needed ...I just got confused because a friend said that its a pain to make it work and I should get the manual harness instead...but thanks for your help bro I appreciated...
Old Apr 25, 2012 | 08:41 PM
np
is the gsr obd 1 ? I should have asked earlier
Old Apr 25, 2012 | 08:49 PM
Dan_EJ1's Avatar
Its obd2 97 b18c1.. but I do want to collect these items so I can make it work...tell me if its good...
-obd1 to obd2 dizzy adapter
-obd1 to obd2 alternator adapter
- my d16z6 injectors
- stay with the p28 or obd1 p72 ecu
Old Apr 25, 2012 | 09:02 PM
you can swap the alt plugs and I believe you can just repin the dizzy, it might just be cheaper to get an obd2 ls harness and depin the the vtec wires from your z6 harness and add them to the LS harness, that way you could use the dizzy, injectors and alt from the gsr without any extra work, the p28 would need to be chipped with at least a base map to run the gsr decently
Old Apr 25, 2012 | 09:14 PM
Dan_EJ1's Avatar
Oh ok...I understand but don't u think it will be a lot easier if I get gsr harness instead since vtec and knock wiring is already there? But ill see what Ill do...right now I'm just collecting parts to get ready for the swap...oh one last thing bro...do I use the gsr power steering bracket to mount my d series power steering pump or do I have to change to the whole gsr pump?? Thanks in advance ...
Old Apr 25, 2012 | 09:36 PM
wow must of posted in another thread or something lol, my post went missing lol
I wouldn't be surprised if the gsr harness is double the cost of an ls harness
when I did my b16a(obd1) swap the pumps were the same it was the mounting brackets that were different, you will need to check the hardline in your car and see if it will bolt to the gsr pump
Old Apr 26, 2012 | 04:48 AM
94EG8's Avatar
Seagull Management
All '92 - '95 EX/Si engine harnesses are the same, it doesn't matter if it came from an automatic or a 5 speed, it's the same harness. It's the cabin harness that differs on those vehicles.
That said an OBD2 integra harness will make your life easier.
Old Apr 26, 2012 | 05:42 AM
Dan_EJ1's Avatar
Ok thanks guys I appreciate your help...
Allurian
Apr 26, 2010 04:31 AM
kasperxtcy
38
Dec 28, 2007 10:49 PM
sleeping beauty
Jun 18, 2004 10:04 AM
