How do you guys cut schedule pipe for manifolds w. angles? How do you bevel?
Old Apr 25, 2012 | 06:15 PM
Urinemachine's Avatar
Default How do you guys cut schedule pipe for manifolds w. angles? How do you bevel?
Silly question but always looking for better ideas. How do you guys cut your schedule piping for different angles? Like say you have a 90 deg std radius 304L weld-el, 1.25 schedule size (sch 10) - how do you cut it down for a clean 45? Clean 15? etc?
Also - how are you guys putting a bevel on your pipes?
Old Apr 25, 2012 | 07:11 PM
SovXietday's Avatar
Default Re: How do you guys cut schedule pipe for manifolds w. angles? How do you bevel?
I use an angle finder to find the angle of the turn and mark it.
At home I use a chop saw and a flapwheel on a 4.5" grinder to bevel.
At work I use a bandsaw and a sander to bevel. Prefer works method, but gotta do what I gotta do at home lol.
Old Apr 26, 2012 | 03:56 AM
How do you hold the pipe at the angle in chopsaw/bandsaw?
Old Apr 26, 2012 | 07:44 AM
roller3804's Avatar
You will have to make a simple Jig. This write up should explain it great. You can modify the design slightly for your application. https://honda-tech.com/forums/welding-fabrication-53/merge-collector-fabrication-101-a-2787713/
Old Apr 26, 2012 | 08:46 AM
^^^ dude... that is EXACTLY the type of thing I've been looking for!
How about for cutting weld-el's on angle? Like cutting a 90-deg down to 30 or 45 deg reliably?
Old Apr 26, 2012 | 10:38 AM
TannerS14's Avatar
How bout go try it out. You really need a belt sander to get perfect fitment unless you want to rely on your cuts every time.
Old Apr 26, 2012 | 11:04 AM
Snow Trooper's Avatar
OG Fabricator
Take the next size up in weld-el and cut it in half length wise leaving a little material to keep it from falling in half on the bottom, the pieces you want to cut will slip inside it.
Weld that to some flat stock that can bolt to your saw bed. The weld-el is now your clamp, use vise grips or any clamping method to squeeze the piece down on the cut piece. If you set it up right it makes life so easy cause the cuts are always perfect in regards to maintaining radius.
Sorry no pics, I will search though for you.
Old Apr 26, 2012 | 12:06 PM
I getcha - so the "clamp" weld-el, make the end parallel to the saw blade/cut off wheel, and then slide the piece to be cut in or out to change the length/angle of bend.
Pics would be awesome, but I get the idea! Thanks!
Old Apr 26, 2012 | 02:44 PM
OG Fabricator
You have the idea, I suck at just text explanations. I recall a poster here showing how he made his version, it was a v8 or v6 turbo suv build thread I think. His was a great example. If I use it soon I will take some shots.
Old Apr 26, 2012 | 04:48 PM
SovXietday's Avatar
With my hands, lol. Sorry OSHA.
Old Apr 26, 2012 | 06:41 PM
Yeah I found it somehow in google - its an infiniti V6 twin turbo
Old Apr 27, 2012 | 08:30 AM
Fotenks's Avatar
I've never welded thin pipe like this before, only thicker pipe that requires 3+ passes.
Do you have a knife edge, bevel with landing, or just a squared edge?
Old Apr 27, 2012 | 08:58 AM
So far I have found it to be ideal to put a bevel on the pipe with a 1/16" or so flat on the end. This way the pipe is not so thin that you burn through. You can get an autogenous first pass this way.
Old Apr 27, 2012 | 02:55 PM
55superbeetle's Avatar
Old Apr 27, 2012 | 04:41 PM
^^^ interesting! I think I like that!
b16bri
Welding / Fabrication
18
Mar 8, 2015 12:10 PM
Walterronny
Nov 18, 2013 01:43 PM
1QwIkEf
Dec 20, 2011 04:31 AM
LSVtechnologytur...
Aug 15, 2008 08:41 AM
Underwhere
15
Jul 25, 2007 02:45 PM
