Bleeding coolant help
Old Apr 25, 2012 | 07:03 AM
h0nda n00b's Avatar
Default Bleeding coolant help
I just changed the water outlet cover on my first gen b16 and cleaned my IACV so i go to bleed my coolant but nothing really happened? I turned the car on with no radiator cap on a slight incline, let it get to operating temperature then put the heat on max. Nothing changed though? My thermostat stayed normal, no fans kicked on, coolant never bubbled up or boiled.
I did a little burping when i first refilled the radiator but thought for sure id need to flush it more. i squeezed the lower radiator hose while i filled it up but would that really be enough?
Old Apr 25, 2012 | 07:10 AM
dunkingmofo's Avatar
Default Re: Bleeding coolant help
thats normal the heater wont raise ur gauge..i didnt bleed my lines at all thats y that new water housing didnt come with a bleeder bolt..ur fan takes a while to.kick on too..nothing sounds out the normal
Old Apr 25, 2012 | 07:16 AM
h0nda n00b's Avatar
Guess I'm just a little paranoid. I waited a good 20-30 minutes with the heater on but those damn fans didn't kick on. Oh well, appreciate the help... again. xD
Old Apr 25, 2012 | 08:01 AM
Mr. EG's Avatar
The 1st Gen B16's should have a "bleeder screw" located on the thermostat housing. Test the fan switch to make sure it is functional.
Old Apr 25, 2012 | 09:24 AM
He just changed the water housing which the original had a bleeder screw and he broke it and got a new one from the dealership, which they don't make them with bleeder screws anymore. So thats y there is no bleeder screw there to bleed, no need to bleeed.
KhmerPride
Apr 29, 2015 05:38 PM
4doorpowa
Jan 24, 2011 12:50 PM
turbotime
Oct 11, 2005 10:08 PM
jadugartir
Aug 4, 2005 12:15 PM
SolidSpruce
Oct 2, 2003 06:42 AM
