Whiper blade skates off the window?
Old Apr 24, 2012 | 09:08 PM
H22_CB7_JAY's Avatar
Default Whiper blade skates off the window?
Well folks the title says it all.
Ive looked at my whiper arm assembly and it all seems fine. The issue is, at higher speeds (usually past 60kmph) my driverside whiper blade skates off the window (while in use) hitting the winshield frame, and making a very loud damaging sound lol.. Does anyone know what you could possibly break internally that would cause this? Plz and thanks!
Old Apr 25, 2012 | 06:06 AM
AutoH22a's Avatar
Default Re: Whiper blade skates off the window?
i have the same problem with my CD5, I have no clue what is causing it..
Old Apr 25, 2012 | 06:45 PM
I get the same answer everywhere I go.. Can someone direct me to a fix? Or atleast direct me to what area on the whiper motor to look.. I have thoroughly gone thru this thing.
Old Apr 26, 2012 | 11:50 AM
StreetsideStig's Avatar
Are you sure it's the motor? I've had this problem on another car, and the wiper arm just needed to be tightened down periodically.
Old Apr 26, 2012 | 12:38 PM
wgbm92's Avatar
I had the exact same problem... well, have the same problem. I have an extra wiper assembly that I have never gotten around to putting in. But what I ended up doing was adjusting the wiper arms. They don't go all the way up like they should, but at least they're not skidding off of the windshield; I didn't want the wipers to break on me in the pouring rain haha. I wish I had a real solution though.
Old Apr 26, 2012 | 09:29 PM
Okay, I'll go to the junkyard and get a replacement setup.. Honestly, my fear is this thing finally snapping on the highway at 110kmph HAH.
Old Apr 26, 2012 | 10:02 PM
MAD_MIKE's Avatar
MM Gruppe B
When your wiper arms are parked are they in the correct position?
POs often futz with wiper arms usually screwing them up.
Check for worn bushings/bearings in the assembly allowing excessive movement. The assembly is powered by the motor, which connects to the P side arm, and then linkage connects to the D side arm. If there is any slop it will be magnified at the D side wiper arm.
Pull the arms up off the windshield, like when replacing blades, and check for any slop in the linkage. If there is equal amounts of rotation from both arms, then most likely the slop is from the bell crank(#7) at the motor. Check that. If that seems fine, it could be that the gearbox(#2) on the motor is worn out allowing excessive play/movement. This would require replacement of the motor as an assembly AFAIK.
Old Apr 26, 2012 | 10:05 PM
Every post, bang on. This man knows his ****. Thank you again sir. I do have alot of play (about half a foot maybe more) when the blades sit on the window. I will bring the laptop out to the car and literaly follow everything you said. Thanks again!
Old Apr 27, 2012 | 10:08 AM
wgbm92's Avatar
I went to replace the wiper assembly today (finally ). Took a little less than an hour to remove and install. Since the weather is beautiful today here in Connecticut, I won't be able to really test and judge whether or not replacing the assembly was worth it. But I sprayed some water with a garden hose on the windshield and they still act retarded like the original one did, and again I tried to adjust the wipers and they don't seem to make a difference. I'll let you know how they work in action!
Old Apr 27, 2012 | 12:19 PM
Thanks bro. What year CB do you have?
Old Apr 27, 2012 | 01:53 PM
wgbm92's Avatar
CD5; 96
Old Apr 27, 2012 | 06:18 PM
Hidenplanvew's Avatar
my prelude did this, never broke.. I just got use to it
BradleBo
Nov 22, 2018 09:26 AM
typeR564
Jul 8, 2008 12:38 PM
GavinJuice
Oct 7, 2006 08:07 AM
KooK
May 4, 2006 03:13 PM
loup05
Nov 22, 2005 12:07 PM
