BC specIII install valvetrain noise
Old Apr 24, 2012 | 08:05 PM
worx's Avatar
Default BC specIII install valvetrain noise
so i just finished installing my cams and I turned it on all good just reved it a bit and i could hear my valvetrain noise. had just did a valve adjustment with the stock cams it was all quiet. Before I installed the cams O asked BC for valve clearance specs and said to leave them stock clearance. im thinking thats not right. any one have experience with these cams? thanks in advance H-T
Old Apr 24, 2012 | 08:11 PM
worx's Avatar
Default Re: BC specIII install valvetrain noise
right now they are set at in6 ex7 it was quiet on stock cams
Old Apr 24, 2012 | 09:33 PM
01oemTeggy's Avatar
Pretty sure its in7 ex8
Old Apr 24, 2012 | 10:03 PM
mouab18c1's Avatar
Buddy Club Spec 3 or Brian Crower?
Always do a valve adjustment with new cams.
Old Apr 24, 2012 | 10:35 PM
worx's Avatar
Buddy club 3s I will try 7 n 8 tomorrow. I had them at 6n 7 and it was quiet
Old Apr 25, 2012 | 05:12 PM
worx's Avatar
just got home bout to do the valve adjustment
Old Apr 25, 2012 | 07:06 PM
worx's Avatar
so valves were off a lil too loose i re did them to in 6 ex 7. with cams would it be normal for the valve clearance loosen up its only been about 100 miles since i adjusted them. any who i turned the car on its a lil quiter but i noticed my timing belt was a bit loose and kinda flapped so imma re do it tomorrow see how it goes.
Old Apr 25, 2012 | 09:24 PM
mouab18c1's Avatar
They only come loose if you didn't tighten them down enough in the first place.
Old Apr 25, 2012 | 09:35 PM
01oemTeggy's Avatar
X2 ^^ pretty sure with aftermarket cams ur supposed to go 7in and 8ex
Old Apr 26, 2012 | 04:57 AM
worx's Avatar
im sure i tighten them good. if it ain't raining ill re do them again and the timing belt as well cause it had lil too much slack
jceltalentoso
Jan 27, 2014 08:54 PM
jdmitr1982
Apr 19, 2006 04:24 PM
super77
Sep 5, 2004 02:19 PM
sikcrx80
May 20, 2003 06:49 PM
infinkc
Jan 22, 2002 09:43 PM
