My GSR Build - Please Comment/Assist/Share Knowledge
Old Apr 24, 2012 | 05:52 PM
Apostle_Is_God's Avatar
Default My GSR Build - Please Comment/Assist/Share Knowledge
Let me begin,
I have a 92 Civic Hatch
I have swapped a JDM GSR B18c motor into it, and need suggestions/comments on how to proceed forward.
Engine Specs: Estimated 13:1 ish compression
Block: B18c - from H Motors
81.5 mm Bore
81 mm B16b pistons + .5 mm CP oversized piston rings
LS Crank (Balanced, machined)
LS Rods (Balanced, machined)
ARP - All bolts (Main, Head, Rod)
Stock .030 Head Gasket (***Want to replace with Cometic .051***)
Head: B18c1 2000 ish* JG Machine work
5 Angle Valve Job/Port Polished
Skunk2 Springs, S2 Tit retainers, S2 Oversized valves (not sure what size, I didn't put it together)
Stock b16a** Cams
slight nic on head surface
S2 Intake Manifold
Megan Header
S2 Full cat-exhaust
330cc Fuel Injectors
Walbro 255 Fuel Pump
Chipped p28 running ITR basemap until tune
Transmission: Stock GSR with upgraded clutch
Here's the question:
I want to upgrade cams, but the oversized valves are keeping me from going S2 pro, must stay tuner series, also need to up the size of head gasket.
Any suggestions on what to do from past experiences? Or just plain comments on my build thanks.
Old Apr 24, 2012 | 06:47 PM
jbpnoman's Avatar
Default Re: My GSR Build - Please Comment/Assist/Share Knowledge
A quick search shows more than one person running Pro series cams with oversized valves. You just have to check your V2V and be careful with it.
Old Apr 24, 2012 | 07:25 PM
anothersickhatch's Avatar
I would suggest staying away from PCT pistons. Try P30's instead. Especially if you plan on driving the motor with an ITR basemap until you get it tuned. With that compression, I don't see your motor lasting long enough to stay healthy on the dyno.
Old Apr 24, 2012 | 07:36 PM
Thanks for the replies guys.
@jbp - I emailed a rep from skunk2's help desk whatever, and he advised me not to use any pro series cams with any oversized valves at all, thats why I said that, but I haven't researched these threads too much about it. So I will look into that thanks.
@anothersickhatch - I don't know if I'm correct on this, but I'm pretty sure I have the pistons from the jdm b16b engine, or at least I thought the b16b pistons were the P30's. There are so many engine codes and piston codes I could be mistaken, so I may have mis typed it in my info, but I meant b16b as to be the jdm b16 with p30s. Correct me if I'm wrong on any of this. Thanks again for the replies guys.
Old Apr 24, 2012 | 10:22 PM
jbpnoman's Avatar
Yeah, Skunk2's "official" stance is to not use their pro series cams with oversized valves, but that hasn't stopped plenty of people from doing it.
As far as pistons, if you're still looking for a set, check out CP. They're some of the best in the industry.
Old Apr 25, 2012 | 04:14 AM
@jbp Thanks man, I appreciate the input. Yeah, forged pistons are pretty appealing not gonna lie, I'll definitely look into S2 Pro cams
Old Apr 25, 2012 | 10:56 AM
Arthas's Avatar
Get it tuned ASAP. None of this basemap bullsh1t.
Old Apr 25, 2012 | 02:55 PM
The B16B is the Civic Type-R engine, which are all JDM. These motors come with PCT pistons, which have an an extremely high dome and account for high compression in anything but the B16B. If you have P30's, then they come from a JDM B16A, not a B16B. In my opinion, P30 pistons are ideal for a daily driven, all motor engine. However, P30's will typically yield between 11.5-11.8:1 compression, depending on the head gasket used, milling that has been done to the head, or whether you use a B18C or B16A head, not 13:1 like you stated.
ko2performance
Engine Machining & Assembly
Mar 15, 2016 10:03 AM
Z0831xiz
May 24, 2015 06:02 AM
jdragon1974
19
Jun 1, 2013 07:37 AM
dc2_530
10
Dec 30, 2011 10:14 AM
DaveF
Jun 17, 2003 12:43 PM
