Made a shift knob today - why not share
Old Apr 24, 2012 | 05:20 PM
mwieczorek43's Avatar
Default Made a shift **** today - why not share
I don't know if this classifies as fabrication or just boredom. Regardless, I decided to waste an hour or so in the garage today and took some pictures while i was at it, might as well waste some of your time while im at it. I wanted to extend my shifter a bit further up, and wanted a new shift *** anyway, so i figured why not kill two birds with one stone. Enjoy
The usual stuff
The jack handle had laying around. Seems solid enough...
Random nuts washers drawer
A couple tacks around the perimeter should do it. Cold welds, whatever ill hit em again later if i need to
Then i boogered the bigger end with the washer. Probably coulda filled the washer hole with something ... but i dont really mind it. Maybe tomorrow
Close-up of the big boogers. Doesnt need to be pretty, a grinder will take care of these anyway
A little grinder action
A little more grinder action
Then some flapper disc magic
A little more flapper action and a sanding block later
Installed. kinda blurry. Oh well
Another installed pic. Stupid camera
Took it around the block and it seems to be right where i wanted it to be height wise. Hand position is a little weird, but i can get used to it. A good waste of time to get out into the garage i suppose. Hope you enjoyed
I decided to go ahead and fill in the washer hole today. Boy that sounds weird...
Scrap piece burned in. Trying to "dome" the top of the shifter
After some grinder action it needed a lot of love. Filled in some spots after this shot and put a little more work into it
Here's a size comparison for you. The pictures from yesterday made it look bigger than it really is
And the final piece. I could put more into making it smoother, but for now its good enough for who its for
Cheers
Last edited by mwieczorek43; Apr 25, 2012 at 05:31 PM. Reason: added some updated pics
Old Apr 24, 2012 | 07:32 PM
essex's Avatar
Default Re: Made a shift **** today - why not share
Nice post , your great with the grinder
Old Apr 25, 2012 | 08:19 AM
^ thank you sir. I need to be with welds like those ;-)
Old May 7, 2012 | 04:30 PM
4drsedaneg's Avatar
made a shift **** today, here is mine
Old May 21, 2012 | 12:08 PM
Damn show-off! You make a write up?
Old May 22, 2012 | 07:38 PM
markspan6243's Avatar
Flattery Will Get You Everywhere
wow thats a great ****!
Carkid95
Jan 21, 2014 07:28 PM
tnewhallSi
Mar 31, 2006 11:44 PM
bigedx
Jan 5, 2004 12:25 AM
Vracer111
May 25, 2002 12:27 PM
joemama
May 24, 2001 05:01 PM
