pipe to flange
Old Apr 24, 2012 | 04:45 PM
b16hybridsol's Avatar
Default pipe to flange
What are you guys using for filler rod on stainless tube to flange welds? I'm about to start on an all 304 stainless header and wasn't sure if 308 would be to brittle for 16ga tube to the head flange.
Old Apr 24, 2012 | 09:28 PM
Default Re: pipe to flange
higher nickel content maybe? hello? ha
Old Apr 24, 2012 | 10:00 PM
EJAYATE's Avatar
I Deliver
For welding 304 to 304 use 308l rod.
For welding 304 to mild or carbon steel use 309
I weld flanges to pipe all day everyday
Old Apr 24, 2012 | 10:23 PM
Yea, I just wasn't sure if anyone used anything different for thin gauge tube to head flanges because of them expanding at different rates
Old Apr 25, 2012 | 12:28 AM
all_motor_mike's Avatar
Mild to stainless use 309
Mike
Old Apr 25, 2012 | 08:57 AM
roller3804's Avatar
Use 309 filler like mike said. The big part is gonna be your heat control, travel speed and torch angle. Make sure to direct the arc slightly into the thicker piece so the molten pool won't pull over to the thinner tubing. Probably wouldn't weld more than an inch at a time in an attempt to prevent warping.
Old Apr 25, 2012 | 09:48 AM
haha, let me clarify. I just wanted to see if anyone used anything different than 308 for stainless flange to stainless tube because of it being a stress point. I know how to weld and what to use in "normal" applications
Old Apr 25, 2012 | 11:00 AM
EJAYATE's Avatar
I Deliver
i use 308 on fairly thin wall material that holds up to 6000psi. Your application falls in the normal category.
90Rexx
Welding / Fabrication
May 18, 2010 09:56 PM
danielm3
12
Mar 2, 2006 06:24 PM
ineedhelp
Aug 1, 2005 05:50 AM
rice a roni
17
Apr 8, 2005 07:58 AM
pub
Mar 24, 2003 04:01 PM
