Removing Exhaust Heat Shield????
Old Apr 24, 2012 | 06:51 AM
MUGENBB4JDM's Avatar
Default Removing Exhaust Heat Shield????
Ok well im going to get my Heatshield painted i see that their are two bolts on the top and one in the bottom. Also see i will need to remove the oxygen sensor. Im just wondering if their is anything else to remove before i go forward with it. If i remove the oxygen sensor will my check engine light come on?
Car Info:
96 Prelude Has OBD II
Automatic
F22a1 motor stock.
Old Apr 24, 2012 | 06:58 PM
T-Mo's Avatar
Default Re: Removing Exhaust Heat Shield????
No and no.
Old Apr 25, 2012 | 04:37 PM
bairdandrew77's Avatar
Why would you remove the o2 sensor?
Old Apr 26, 2012 | 02:37 PM
TheJGB3's Avatar
Which heatshield are you referring to? The one on the cat (#5 & #6), or the one that is bolted to the bottom of the car that runs from the downpipe/flexpipe all the way to the muffler (#27, #28, & #30)?
Old Apr 28, 2012 | 06:28 AM
Sorry i am removing the exhaust manifold heatshield the one in front of you when you open the hood with the image of a hand with a line across it.
Old Apr 28, 2012 | 07:29 AM
southie's civic's Avatar
just unplug the connector
Old May 1, 2012 | 01:20 PM
TheJGB3's Avatar
What connector? The upstream O2 sensor is in the downpipe.
Old May 1, 2012 | 06:02 PM
holmesnmanny's Avatar
http://www.hondapartscheap.com/find-...FOLD%20%281%29
Just unplug the sensor like everyone said. After you put the heatshield back on just plug it back in. It should slide off over the oxygen sensor would be my guess.
lol it won't throw a code unless you drive the car.
Old May 1, 2012 | 06:31 PM
Hidenplanvew's Avatar
O2 is in the downpipe, just unbolt it and pull it out
Old May 1, 2012 | 08:14 PM
No, it's not. Look at the pic in my link. That's his car.
Old May 2, 2012 | 06:46 PM
Then just unplug it and pull the over off.. to easy! You take the shield off to change the O2 sensor anyways
Old May 2, 2012 | 08:53 PM
BergRacing21's Avatar
are we serious? is this a serious question...3 bolts and unplug a sensor
Old May 2, 2012 | 08:55 PM
other sad part about this thread is he is "going to get it painted"...it's a heat shield paint it yourself.
Old May 3, 2012 | 12:05 PM
daveypower's Avatar
Give the lad a break, he can do what he wants.
Old May 3, 2012 | 06:28 PM
yeah you're right. i still think this thread is a joke
Benevolent27
Jul 12, 2010 01:26 PM
EG-SIXV-TEC
Feb 7, 2009 01:14 PM
Bobby01
Sep 4, 2007 06:04 PM
rockdude14
Dec 4, 2005 12:18 AM
TEG98
Jun 17, 2004 10:07 AM
