wipers dont return to rest position
Old Apr 23, 2012 | 08:39 PM
Tim Steele's Avatar
Default wipers dont return to rest position
recently bought a 95 integra and when i shut the wipers off they stop wherever you turn the switch off. The 2 different speeds work. This isnt my first honda just havent ran into this problem. Am i looking at getting a new wiper motor or are there a few things to check first?
Old Apr 23, 2012 | 09:28 PM
FlewByU352's Avatar
Default Re: wipers dont return to rest position
Both my EJ8's have had this problem. Its very annoying and I rarely use my wipers. In fact I keep them unplugged unless it starts raining hard then I reach under the column and plug it back in.
Old Apr 24, 2012 | 12:55 AM
Runnerdown's Avatar
This problem comes from the wiper motor itself, yep it's pretty common
Old Apr 24, 2012 | 04:24 AM
Tim Steele's Avatar
Thanks man. ill see if i can find one at the junk yard this weekend. is there any threads on the wiper motor swap? lol im sure i can handle it. appreciate the help
Old Apr 24, 2012 | 05:41 AM
fcm's Avatar
fcm
Old Fart
I would check the ICU, intermittent wiper and park is controlled by the ICU.
Are you having any other ICU related problems, does intermittent wipers work, does rear window defog work, do all your warning chime functions work, [lights still on, key still in ign., seat belt warning]? 94
Old Apr 28, 2012 | 09:08 PM
Tim Steele's Avatar
i found a wiper motor off a eg and tried that. still the same problem. how would i go about looking into the icu? ive never dealt with that before.
Old Apr 29, 2012 | 08:45 AM
fcm's Avatar
fcm
Old Fart
The ICU, [Integrated Control Unit] is mounted to the back of the under dash fuse box...
http://www.hondaautomotiveparts.com/...R+HEAD+%281%29
The white box, it unplugs/unclips from the fuse box.
It may be repairable, search for the "fix", in most cases all that is needed is a new capacitor. 94
Old Apr 29, 2012 | 06:39 PM
Nailclipper's Avatar
I had this problem and it was the actual switch you turn of and on. My2c
Nancyrc23
Jul 9, 2008 06:16 AM
jdmturbo1127
10
May 25, 2007 06:48 PM
99tegra
Mar 14, 2007 02:21 AM
dwn4cause
Jan 12, 2005 10:02 PM
