*noise coming from from right side of car 93 integr gs 4door
Old Apr 23, 2012 | 01:12 AM
ksettles619's Avatar
Icon3 *noise coming from from right side of car 93 integr gs 4door
ever since I got the car it has been making this screeching noise. I don't know what it is or how to explain it so I made a video. It happens when i'm driving and is constant and repetitive. Someone please help https://www.youtube.com/watch?v=3stI...e_gdata_player
Old Apr 23, 2012 | 03:29 AM
Black_horse's Avatar
Default Re: *noise coming from from right side of car 93 integr gs 4door
I'm not sure about the sound , can't realy tell , I assume it is air leaking sound from the door , if it only happen while driving and gets higher with speed, check the rubber around the door , make sure they are well stuck , maybe they need to be replaced or door is loose a bit.
Have someone next to you to confirm where the screeching sound coming from , make them pull the door to see if it will gone .
I too have lil screeching sound on my sunroof fixing it cost more than fixing door lol
Old Apr 23, 2012 | 06:29 AM
JustDoingMe's Avatar
Does it screech if the window is up?
Old Apr 24, 2012 | 09:27 AM
Its not coming from inside the car I should've been more detailed. I hear it from the front passenger tire area. Its so loud that I can hear if in my car when im driving. I usually have the music blasted to avoid it.
Old Apr 24, 2012 | 11:23 AM
Go take it for checkup , even if you know what's wrong with it you can't fix , unless you are specialist . Could be brakes or discs , I don't think anyone here can help.
You need a specialist look there.
Old Apr 27, 2012 | 11:49 PM
Will do thanks!
msaeger
Honda Civic (2001 - 2005)
May 12, 2012 09:26 PM
bitbycarbug
Nov 24, 2006 05:00 PM
loup05
May 22, 2006 08:47 PM
ThisLittleSleepeR
Nov 15, 2004 09:40 PM
CaTiRo
Mar 25, 2004 08:49 PM
