Idle drops with A/C on..
Old Apr 22, 2012 | 08:07 PM
KAnnabistECh's Avatar
Default Idle drops with A/C on..
Hello their, I have a 1995 Civic Ex Sedan with USDM B18C1, CTR cams, Hondata S300J on Jdm P72 ECU... When the engine is at normal operating temp Idleis at 850rpm and I switch on the A/C the Idle drop excessive.. What I'd like to know is the Difference in Electrical configuration... USDM ECU's use an ELD, JDM ECU's do not.. I'malready using the D10 for my Wideband Sensor.. What can I do to eliminate this using a JDM ECU with a USDM B18C1..
Old Apr 22, 2012 | 08:11 PM
Gunmetal_B20_Hatch's Avatar
Default Re: Idle drops with A/C on..
try upping the IAC duty cycle in your Hondata program
Old Apr 22, 2012 | 08:13 PM
Gunmetal, I will try that at work tomorow and give feedback.
Old Apr 22, 2012 | 08:19 PM
famous323's Avatar
or clean the screen on the iacv.
Old Apr 22, 2012 | 08:22 PM
Has a new IAC Valve.
Old Apr 22, 2012 | 08:23 PM
Yes, its OEM
Old Apr 23, 2012 | 12:33 PM
Ok, Gunmetal so I took my laptop to work and started increasing the IACV slider one increment at a time. All it's doing it's increasing my idle. Idle still drops to about 530 then it kicks up to 730.
Old Apr 23, 2012 | 02:41 PM
Looking at the ETM the US ECU's have an ELD input at D10 which like I said earlier is used for my WideBand Sensor, and other is an Output at A16 which is Alternator Output Signal... Should I also "Disable" the Alternator Output Signal in my Hondata???
Old Apr 23, 2012 | 02:47 PM
Or Remove pin A16 from Connector??
Jonathan Doe
Honda CR-V & Element
Sep 30, 2015 05:27 AM
t-del28
Sep 24, 2012 02:27 PM
LostSolVTEC
Jul 22, 2004 04:31 PM
slimbo
May 16, 2004 10:57 PM
GruvyTune
Aug 29, 2002 10:27 PM
