RIGHT SIDE HEADLIGHT LOW
Old Apr 22, 2012 | 05:05 PM
civicpark81's Avatar
Default RIGHT SIDE HEADLIGHT LOW
So I just took out the HID kit on my EJ1 and put the stock headlight set up, but the right side is super dim. At first I thought it might be the contacts were on wrong and i had reversed the polarity, but it wasnt that. I switched bulbs from the left side but issue remains, highbeams are the same issue. Any idea whats causing this??
Old Apr 23, 2012 | 06:14 AM
Default Re: RIGHT SIDE HEADLIGHT LOW
bump
Old Apr 23, 2012 | 07:16 AM
slyda24's Avatar
Was the HID kit installed by you? or you got the car like that? Also what you're saying is one side headlight is always dimmed even if you switch bulbs from left to right, high beam to low beam?
Old Apr 23, 2012 | 07:27 AM
no i didnt intall the kit,but it was a plug nd play that used the stock plug. yes, ive switched the bulbs and it only on right side.
Old Apr 23, 2012 | 07:31 AM
gold_pwr_r4ng3r's Avatar
it could be a blown fuse, the same thing happened to my friends 03 civic and it was just a blown low beam fuse.
slyda24's Avatar
Was the Hid kit for both low and hi beam or just low beam? Also how does your headlight socket look, factory socket or aftermarket? sounds like it is wired incorrectly if one side is low. When you say you reversed polarity, what exactly do you mean?
Old Apr 23, 2012 | 07:40 AM
the kit was only 1 stage, no high beams. i thought the wiring was off so i moved the wires to different positions but no go so i put them back to original position. i replaced socket cause i thought there might be a short.
Old Apr 23, 2012 | 07:42 AM
slyda24's Avatar
From the socket, there are 3 wires, you just needed to move 2 wires as the black was ground and stays the same, so those were the 2 you moved around and still no results so you put them back the way it originally was, So then i would check the fuse as Gold Pwr stated for that one side headlight.
Old Apr 23, 2012 | 07:45 AM
ok thanks guys...fuse makes sense. do each headlight have its own fuse?
Old Apr 23, 2012 | 07:50 AM
slyda24's Avatar
Yes, look for your specific Honda here and it will tell you what the fuses are.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/civic-del-sol-fuse-panel-printable-copies-fuse-diagrams-here-1966666/
Honda Rules
Lighting
Jan 20, 2008 01:14 AM
J.nguyen
Honda S2000
Aug 13, 2007 11:44 PM
speedymon
Nov 19, 2002 11:28 AM
Tony the Tiger
Mar 12, 2002 09:40 PM
