I Need Help ASAP!
my 1995 honda accord 2.2l vtec doesnt start. My distributor only shoots a spark when it wants or when i play with the smaller connector of the two that come out of the distibutor its a little broken but it doesnt convinse me that its the problem. when i try cranking it and stop the ignition coil starts shooting out sparks at random. at first i thought that was the problem but no change so i dont know. someone help please
Have you checked your fuel pressure? Is you main relay working fine b/c they have a tendency to fail. When you turn the key to the on position, does you check engine light come on and go off after 2 seconds?
il have to check the relay then but the fuel pressure is fine but il double check it still doesnt answer why my ignition coil seems to be throwing sparks even when your not cranking engine or its completely off
No More Civic
10
Aug 27, 2002 09:35 AM
