engine ok?
Old Oct 12, 2002 | 06:01 AM
12345's Avatar
Default engine ok?
i just got a itr motor/trans that was in an accident and the timing belt broke. i took off the head and the valves and pistons didn't get damaged. what else should i check?
Old Oct 12, 2002 | 06:28 PM
BreakStuff's Avatar
New User
Default Re: engine ok? (12345)
If the T-belt snapped it may not easy to visually see any damage if the valve contacted the piston..
If the cams had to be removed as part of the head removal, then all valves should be "shut"..
One of my test's for checking valves is to pour water down the intake and exhaust ports to see if the valves seals are tight... If you see water dripping from a valve or valves, then you will know its not making a good seal...
Old Oct 14, 2002 | 02:36 PM
12345's Avatar
Default Re: engine ok? (BreakStuff)
when i look at the valves they are all shut. i'm going to try checking it with the water. thanks
Old Oct 14, 2002 | 03:37 PM
IN VTEC's Avatar
I use carb cleaner so it doesn't rust the valves.
But, the choice of water or carb cleaner depends on whether or not you're gonna overhaul and clean everything.
My valve damage was also visually undetectable. A compression test showed a 160 point drop in compression in one cylinder and a liquid test showed a leak in one of the exhaust valves on that one cylinder.
If you do have a valve problem, I would play it on the safe side and get new valve guides, so that when you get the new valve seats cut, they'll be nice and true for the cutter guide.
Old Oct 14, 2002 | 04:41 PM
94gsr's Avatar
Default Re: engine ok? (IN VTEC)
Water is too dense. Use brake parts cleaner or carb cleaner, (as was already suggested), it's much thinner & will be a more accurate test for any leakage.
Old Oct 14, 2002 | 05:49 PM
12345's Avatar
Default Re: engine ok? (94gsr)
ok, thanks. luckily i checked this before i started. i'll try the carb cleaner and see what happens. also, i was wondering how i could clean off the black crap on the pistons. thanks
Old Oct 15, 2002 | 01:22 PM
12345's Avatar
anyone know how i can clean the black stuff on the pistons?
[Modified by 12345, 6:39 AM 10/16/2002]
grinder_1
Classic Hondas
Feb 17, 2026 01:44 AM
cloudconnected85
Dec 30, 2009 02:47 AM
twentyhurtz
Sep 15, 2009 10:38 AM
civicmitch
Apr 27, 2009 02:07 PM
smokey2.0
Dec 27, 2003 05:18 AM
