Start Up Issues
Old Apr 22, 2012 | 09:19 AM
phat00civic's Avatar
Default Start Up Issues
I figured I would ask here as I am starting to see some start up issues. What occurs is the car will crank but will either not turn over or if it does I have to give it some gas. I am thinking it is the fuel pump or injectors no? My reason for that is that I step on the gas to help the motor from killing out. Once the motor is on, I have no issues. Thoughts?? Ideas?? I do use premium fuel from Hess or Sunoco and it occurs regardless if the tank is full or 1/2. The reason for premium is I am boosted. I hate self diagnosing
Old Apr 22, 2012 | 09:55 AM
jdmem205's Avatar
Default Re: Start Up Issues
have you checked your main relay that gives power to your injectors and fuel pump search about the honda start up issues and you can see what I am talkin about
Old Apr 22, 2012 | 09:59 AM
motegicivic's Avatar
See what your fuel pressure is, use a gauge to the top of the fuel filter.
Old Apr 22, 2012 | 10:03 AM
Sorry I forgot to mention that. Yes, I did just replace it and it is now worse. It was random before I swapped it out with a new one. I think you are referring to this, no? I threw the original one out that was in the car too :-(. It was $80 from Honda.
http://techauto.awardspace.com/civicrelay.html
I think what I should try, is turn the key to position 2 for the fuel to prime, wait a sec or two, and then try to turn the motor on?
Old Apr 22, 2012 | 11:16 AM
Ok so I let it prime for a sec or two longer and car starts right up, no problem... interesting.
Old Apr 22, 2012 | 11:22 AM
beecee18's Avatar
You have to check fuel pressure at the filter or rail to see if the check valve in the fuel pump is bleeding off, your symptoms kinda sound inline with that problem. After you turn the vehicle off the check valve is supposed to hold fuel pressure for the next startup.
You will exibit these symptoms your stating and others when this is not functioning correctly. If your pressure bleeds off you will probably be looking into replacing the assy.
Old Apr 22, 2012 | 11:27 AM
beecee18's Avatar
There is no letting it prime for longer,
The ecu applies power to the fuel pump for 2000ms(2sec) on key position #2,
unless you just slam the key in it and just go straight to start, which shouldnt be a problem.
Old Apr 22, 2012 | 11:28 AM
Originally Posted by beecee18
You have to check fuel pressure at the filter or rail to see if the check valve in the fuel pump is bleeding off, your symptoms kinda sound inline with that problem. After you turn the vehicle off the check valve is supposed to holding fuel pressure for the next startup.
Yea I was thinking that but the fuel pump is new, probably 3K miles on it. Its a WALBRO 255LPH. I never heard of them having this issue new?
My injectors are old and used, thinking I should send them out?
I should probably replace the fuel filter as well. I am not sure if it has ever been replaced and the car is at 136K miles.
Old Apr 22, 2012 | 11:29 AM
In regards to that, I typically do place the key in and go right to start. When I did it before I waited those 2 seconds...lol
Old Apr 22, 2012 | 11:40 AM
slyda24's Avatar
Clean your throttle body, check the iacv. If your car was not getting any fuel i doubt it would start at all. Have you driven this car btw.. if so, how far? noticed anything weird as you are accelerating/decelerating?
Old Apr 22, 2012 | 04:29 PM
IAVC??? I do not see how that would cause my issue....my idle is fine.
Old Apr 22, 2012 | 06:37 PM
Just so you know Honda's do not like WALBRO fuel pumps.
Old Apr 22, 2012 | 07:37 PM
Former User's Avatar
You MUST provide all pertinent information about your car and engine. Failure to do so may result in thread closure.
Old Apr 22, 2012 | 09:36 PM
Where can I read this??? I know plenty of guys running them with out a problem. Please provide factual information for me.
Kid-jdm-teggy
Sep 13, 2013 09:20 AM
Pr0ject93hb
Feb 25, 2007 08:34 AM
RA12825
Jan 29, 2007 08:51 PM
mattstru
Apr 26, 2006 05:42 AM
davechuck
Mar 18, 2004 04:10 PM
