CEL code 14 only with the service jumper conected
hi guys.
today my car got a idble problem, it has fluctuating idle, with the engine running any cel but when connect the jumper for service the code 14 blink on my CEL, any idea?
i already clean the iacv, i was checking the wire harnnes cuz, sometimes when the fluctuating idle happen moving the wires fluctuatig idle disappear, there is a way for wiring a paralel line to see the iacv behavior?
So your saying when you mess with the wires it goes away?
yes, IAVC Wires.
i do the service manual procedure for the code 14 and all seems to be good, but when start the engine idle start on 1200 rpm, and then slowly goes down below 500 rpm, when the engine is at operating temperature and disconnect the iacv nothing happen, but when connect it again you can hear the click sound, idle goes up for a moment and then goes down again.
if you rev up the engine and then let in idle again, the fluctuating idle appear
yes, IAVC Wires.
Bleeding the cooling system may take 20-30 minutes.
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below (hint: the bleed bolt is located where the upper radiator hose connects to the engine):
Is the coolant level low in the radiator? Have you tried bleeding the cooling system?
