____NEED HELP FROM wiring Experts type R distributor!!!!
Old Apr 21, 2012 | 03:44 PM
OhMy-EK9's Avatar
Default ____NEED HELP FROM wiring Experts type R distributor!!!!
car is 2000 acura integra type r
problem is car wont start at all its a obd2b gsr ecu motor is 95 gsr engine wiring is original 2000 harness and i converted to obd1 injectors and alt wiring my issue is wiring up the distributor correctly all the diagrams i fine are different.
body side type r harness wire colors
total of 8 wires
.1:yellow/green
.2:white
.3:black
.4:red
.5:yellow
.6:green
.7:blue
.8:black / yellow
now my distributor is obd2 big plug w
total of 9 wires
.1:black / yellow
.2:blue
.3:yellow / green
.4:blue / green
.5:blue /
.6range / blue
.7range
.8:white / blue
.9:white
every single wiring diagram i see is different i need to know the correct order or these wires any help will be greatly appreciated. thanks
Old Apr 21, 2012 | 06:00 PM
kyosoeg6's Avatar
Default Re: ____NEED HELP FROM wiring Experts type R distributor!!!!
Why would you hack everything together in the first place ? Post pics of your distributor and i can help u to from there
Old Apr 24, 2012 | 07:12 PM
94rs-turbo's Avatar
so your dring to rewire your obd1 dizzy to obd2?
Old Apr 24, 2012 | 09:56 PM
S2kRyan's Avatar
If so, they make a sweet little conversion harness for this and it can't cost that much.
egreenmachine
Feb 24, 2009 11:05 AM
everythingwentblack
May 7, 2006 03:20 PM
