Rear endlinks are annoying! Help
K I have a 93 del sol and I put on a Asr brace and itr 22mm sway bar with Asr endlinks. Well the endlinks are brand new and annoying as ****. They rattle on my exhaust and make clunking noises. What kind of endlinks should I run? And how do I stop it from rattling!?
did you install these with the suspension under load?
you want the sway at a neutral setting while installing the end links. Either use a roll-on lift or use ramps in the driveway
No I had it up on jack stands. I'm going to pull the endlinks and re install them maybe I installed them wrong. Here's the website I'm using to follow step by step. http://www.clubcivic.com/board/showthread.php?t=69833
floridaEg8ferio
Suspension & Brakes
May 12, 2011 09:31 PM
scottsopko320
Jul 29, 2008 12:55 AM
