welding flanges... what went wrong?
Old Apr 20, 2012 | 11:30 PM
85's Avatar
85
Default welding flanges... what went wrong?
this is the first flange ive ever welded... I had some trouble getting enough heat to make it stick to the flange and not burn the tubing. any advise? done on a tig. sorry it's not the best picture.
Old Apr 21, 2012 | 07:11 AM
ihaterust's Avatar
Default Re: welding flanges... what went wrong?
angle torch on flange and get a nice pool then blend the puddle into the tubing.
Old Apr 21, 2012 | 09:54 AM
2000CTRSi's Avatar
You need to put more heat towards the flange.
Old Apr 21, 2012 | 10:25 AM
roller3804's Avatar
When you are welding a thick stock like a flange against a thinner gauge tubing the molten pool will want to pull into the thinner stuff because it heats up faster. Direct the arc slightly up onto the flange and let it pool into the thinner stuff. If you have a foot pedal use it lol.
Old Apr 21, 2012 | 01:58 PM
85's Avatar
85
the weld seems ok but it took way longer than it should have. I'll try that on the next one. thanks.
Old Apr 21, 2012 | 09:23 PM
SQ is the SQUAD's Avatar
would it help if he preheated the flange?
Old Apr 22, 2012 | 12:43 PM
EFjoe91's Avatar
PUT more heat into all together. Current. Angle. Speed. all play a key role in welding. Low heat LONG time. High heat QUICK work time.
Here is a photo of a stainless project I finished up yesterday. This was welded with around 50 welding amps. material is pretty thin wall and I have been welding everything V bandTHe v band flanges are pretty thick and I had welded my first flange with .30 Stainless MIG wire.
THis was a special FUNNEL part I waited on and finally made my transition the way I wanted to.
Old Apr 23, 2012 | 07:26 PM
copy's Avatar
why didn't you use a chill ring ?
Old Apr 24, 2012 | 11:36 PM
TannerS14's Avatar
Advice man needs advice.
Old Apr 25, 2012 | 12:26 AM
all_motor_mike's Avatar
Lol, I was thinking something similar except my thought included the word thread jack also. When welding thick material to thin OP, focus the arc on the thick material and as u dip ur rod it should fuse over onto the thin material. It takes some practice and if those are ur first welds then u can't be to dissatisfied with it.
Mike
Old Apr 25, 2012 | 05:42 PM
copy's Avatar
If he had used a chill ring he would have had this done right the first time
Old Apr 25, 2012 | 07:07 PM
SovXietday's Avatar
I know you went to school and everything, but your welds are way hot and way undercut.
Old Apr 25, 2012 | 07:49 PM
EJAYATE's Avatar
I Deliver
It looks like you are trying to add too much rod for the amperage you are welding at. The weld doesnt need to be any thicker than the thinnest base material.
Old Apr 26, 2012 | 10:28 AM
2000CTRSi's Avatar
U gguys made pics so big I feel like im using google maps searching for the street on this smartphone
Old Apr 28, 2012 | 08:47 AM
vtec_lude's Avatar
85- I feel when welding flanges, going for a higher amp is better than being too low. Aim the pool towards the flange like everyone else says.
Also don't listen to the guy with the huge pictures, he still needs to work on his welding before he should be giving advice.
EFjoe91- You need to work on consistency and setting your welder right. Most of the welds are cold and don't look great no matter how you polish it. Go for more heat and work on keeping you torch steady.
Gl folks.
Old May 1, 2012 | 07:19 PM
copy's Avatar
EFjoe91- Try working on consistency and reading the instructions on your welder. A lot of the welds are cold and don't look so great they way you have been doing it . Try more heat and keep your torch steady. If I can be of any more help let me know. I was a newbie once 2.
Old May 2, 2012 | 01:00 PM
McRussellPants's Avatar
Both of you are melting filler and then trying to push it into the part with heat.
melt first, filler after. If you dab on top like that and then push it in with heat and the HAZ/inclusions are going to be out of control.
Old May 7, 2012 | 03:58 PM
GearHeadDeals.com's Avatar
probably everyone said this but that's what you need.
MidShipCivic
Welding / Fabrication
12
Mar 5, 2010 05:31 AM
*Boostwerks*
45
Apr 13, 2009 06:50 PM
JCushing
May 21, 2006 11:34 AM
own6volvos
10
Aug 8, 2005 04:57 PM
youngkow
Mar 25, 2003 12:40 PM
