2000 civic clutch pissing me off!!!!
Old Apr 20, 2012 | 08:04 PM
civicexkid1's Avatar
Icon2 2000 civic clutch pissing me off!!!!
i bought a 00 ex about 4ish months ago and cant get a constant smooth shift out of it, every other car is fine i just cant feel the engaugement point, theres virtually no restience so i always go through it and it never works out. the clutch pedal also seems very high. can that have anything to do with the feeling? the car has 126,000 miles on it i dont know if the clutch has been done before. its just making me really mad. any help would be great...at all
Old Apr 20, 2012 | 08:32 PM
Default Re: 2000 civic clutch pissing me off!!!!
i also only have to push the clutch down maybe 2'' for it to disengage and i push all the way to the floor so it makes travel from floor to top really far and thats mostly my probelm.
Old Apr 21, 2012 | 03:43 AM
grumblemarc's Avatar
The Grumpiest
So adjust the clutch pedal. There should be a link in the FAQ if you don't know how. Edit. There wasn't.
https://honda-tech.com/forums/showpo...31&postcount=7
Old Apr 21, 2012 | 04:53 AM
94EG8's Avatar
Seagull Management
Originally Posted by DSMAddicted
What you do is loosen the nut that keeps the metal rod from twisting. Then twist the rod a few increments (maybe 1 or 2 turns). Tighten the nut back and try it. Repeat until you got the clutch engaging at a desirable point.
Don't adjust your clutch pedal like that. Follow the procedure in the service manual, set the freeplay and disengagement height, when you're done the engagement height will be wherever it's supposed to be.
Adjusting it wherever your want it can cause disengagment issues, slipping, and increased snychro wear depending on which way, and how far off your adjustment is from where it should be.
Old Apr 21, 2012 | 05:13 AM
The Grumpiest
Lemme find a proper procedure. Sorry.
http://www.civicforums.com/forums/12...djustment.html
Old Apr 21, 2012 | 05:38 AM
94EG8's Avatar
Seagull Management
It's further down if view the thread that post you linked to is from.
Old Apr 21, 2012 | 05:43 AM
The Grumpiest
Yeh. Grabbed the wrong posting. Here's Ron's resource.
Old Apr 21, 2012 | 05:45 AM
94EG8's Avatar
Seagull Management
Old Apr 21, 2012 | 06:05 AM
alright ill try this later today. thanks guys
PunchedGuava
Jun 4, 2013 09:30 PM
jdmcivicracer89
21
Jun 5, 2008 09:39 AM
crazycivichatch
10
Dec 9, 2006 07:54 PM
typeee
Dec 21, 2002 03:41 AM
Sohc Driver
15
Aug 25, 2002 04:52 PM
