95 EJ2 rywire engine harness through firewall
Old Apr 20, 2012 | 07:03 PM
StevieR's Avatar
Default 95 EJ2 rywire engine harness through firewall
Searched, couldn't find anything that helped. I'm trying to run my engine harness through the firewall to the ecu. I can't find a spot to route it and I'm getting frustrated.
I've tried the passenger side hole that has the fuse box wiring. It's too tight to fit the connectors through. Also tried the drivers side hole with the same issue. Where do I route this thing? Such a PITA. Don't want to have to take off the entire dash, but I cannot fit my hands behind all the **** there. Thanks in advance.
Old Apr 20, 2012 | 07:28 PM
MRGRIM's Avatar
R.I.P. Mark
Default Re: 95 EJ2 rywire engine harness through firewall
search this thread its your best bet for options
https://honda-tech.com/forums/showth...3934&page=1291
Old Apr 20, 2012 | 10:36 PM
Mikasa's Avatar
Have you tried depinning the wires from the connectors?
Old Apr 20, 2012 | 10:44 PM
doood's Avatar
been there done that
Have you tried contacting rywire?
Old Apr 20, 2012 | 11:01 PM
StevieR's Avatar
I'm not going to de-pin every single clip so I can route it through and re-pin it. Also, I have contacted rywire. I've figured it out myself though. For those who may run into the problem later, if you don't have ac remove the evap box and route through there. It is much more simple than it looks. All the clips will fit through either way. No real fighting with anything. May be different for EK's though. Not sure how the firewall is on those.
Old Apr 21, 2012 | 08:50 AM
crx_si-r's Avatar
Most of the time it's ran through the a/c port. With a tuck a/c is generally removed
lolv8s
May 17, 2013 05:20 PM
07BBS2K
Aug 3, 2010 02:43 AM
coolguy660
Aug 30, 2006 09:45 PM
RicedREX
13
Apr 20, 2005 06:46 PM
SkRiBLaH
14
Dec 26, 2004 08:35 PM
