98 civic - bad idle for ~30 seconds after start up
Old Apr 20, 2012 | 06:01 PM
98EJ7Y8's Avatar
Default 98 civic - bad idle for ~30 seconds after start up
sometimes when i go to start my car it will start up and idle perfectly fine .. but then other times ill go to start it and it will start but have a terribly bad idle for about 30 sec than catch the idle back up to speed .. kinda like its choked out of gas .. when it idles like this the car shakes real hard .. hard to explain but the car putts sometimes when starting .. i dont see how this could be a fuel problem unless its the pump itself .. i run premium gas everytime since i had engine work done about a month ago
Old Apr 20, 2012 | 06:53 PM
mysayasan's Avatar
Default Re: 98 civic start up
Is there by any chance you tune the car by yourself by using aftermarket engine management like HONDATA, Chrome, etc
Old Apr 20, 2012 | 07:37 PM
98EJ7Y8's Avatar
F-***... i got an ecu from the internet .. that was tuned to my engine but it wasnt a dyno or anything .. u think it could be tuned wrong .. maybe for bigger injectors
Old Apr 20, 2012 | 09:25 PM
4drferio's Avatar
check iavc
Old Apr 21, 2012 | 03:29 AM
jbpnoman's Avatar
"The internet" is very vague. Where specifically did you buy it? Yes, if it's running a custom tune, that might be your problem.
Old Apr 21, 2012 | 03:33 AM
grumblemarc's Avatar
The Grumpiest
Probably Ebay or Craigslist. Did it run with the stock ECU?
Old Apr 22, 2012 | 07:16 PM
98EJ7Y8's Avatar
EBay .. its a chipped p28 .. obd1. Yeah its pretty vague but I told the guy exactly what I was running .. aNd no it has a jumper harness on it
Old Apr 22, 2012 | 11:53 PM
mysayasan's Avatar
Try to run it with stock ecu first and see how it goes.
Nolenrob7
18
Apr 4, 2017 03:30 PM
cjwang2
Jul 8, 2016 01:10 PM
lkiss
Honda Civic (2001 - 2005)
Mar 22, 2016 10:20 AM
eriki
Apr 8, 2013 10:28 AM
