installing a new slim fan
Old Apr 20, 2012 | 02:25 PM
whasian's Avatar
Icon6 installing a new slim fan
okay so yesterday my stock fan went out on my del sol,so im ordering a blox slim fan.im wanting to put it on as a pusher so which way should the fan blades be spinning??any help would be be appreciated
Old Apr 20, 2012 | 02:32 PM
grumblemarc's Avatar
The Grumpiest
Default Re: installing a new slim fan
You have a 50/50 chance of getting it right. Wire it up. If it blows the wrong way then swap the wires around.
Old Apr 20, 2012 | 02:38 PM
apexi_rsx's Avatar
it can be hooked up to push or pull whatever way u decide to mount it. if its blowing the wrong way as grumble said swap the wires and it will spin the right way. you can always test what way to hook it up on your battery temporarily and figure out what way to connect it. i recommend using the plug or wires coming from your OEM fan so it runs off the stock fan switch.
Old Apr 25, 2012 | 12:38 PM
whasian's Avatar
thanks for the help and info guys
this morning i got woken up at 8:30 by my doorbell and found this
and then i opened it and found this
and now my car looks like this and is running again and i got the fan pushing the air into the radiator
Old Apr 25, 2012 | 01:38 PM
cvcrcr99's Avatar
^^Looks good.
Straight blades? Then just reverse polarity.
Curved blades? I believe you have to remove the blade, flip it upside down and then you are good (no wiring changes).
I have been running a straight blade fan as a pusher for years with no problems.
Old Apr 25, 2012 | 03:11 PM
DontTouchMyEj1's Avatar
how does it run like that ? any problems or anything at all ?
im interested in doing the same for my car .
Old Apr 26, 2012 | 06:18 AM
cvcrcr99's Avatar
What do you mean how does it run like that? Is it a fan. The angle of the straight blades changes how air is affected if the fans spins differently.
Spin one way and it will push, spin the opposite way and it will pull.
I just said I have been using a fan like this for years. Why would you then ask if we are having any problems with it. Obvious answer is obvious.
Old Apr 26, 2012 | 03:38 PM
HondaTuner4267's Avatar
Nice! I need to get around to installing mine.
zeb1117
Apr 3, 2010 09:33 PM
Metal Head
Jul 22, 2008 11:42 AM
Doh!
Jul 3, 2006 09:29 PM
Project_ED8
Dec 1, 2003 05:50 PM
