Very low Idle**have done all the checks**
Old Apr 20, 2012 | 02:19 PM
MeCrObS's Avatar
Default Very low Idle**have done all the checks**
my Car idles fine at start up but as soon as i am sitting at a stop sign or a red light the idle drops to around 400-500rpm, then it will eventually drop to around 200rpm. I have cleaned the IACV and the FITV and adjusted the idle screw in the FITV and still have this problem. My injectors are not the problem either(saw on another forum that they could have play a role in a bad idle)
Someone help please. I have a link to a video i took of my idle issue, as you can see it is idling way to low and it sounds like its almost just gonna cut off every time it drops to like 200rpm. I have no clue where to start next...
http://s627.photobucket.com/albums/t...420_174359.mp4
Old Apr 20, 2012 | 02:47 PM
exiguitas's Avatar
Default Re: Very low Idle**have done all the checks**
let me know if you find out the solutions. i think im having the same issue.
Old Apr 20, 2012 | 04:31 PM
MeCrObS's Avatar
Yeah will do^, but i don't think anyone is gonna help lol
Old Apr 21, 2012 | 07:01 AM
Kyo1986's Avatar
In the video link you posted the engine never drops below 650 rpm.
Old Apr 21, 2012 | 07:10 AM
dunkingmofo's Avatar
Are all your vaccum lines hooked up in the right stop, because my car use to run fine until I stop and it would drop to 200 rpms and kill sometimes and once I got my lines in the right stop and readjusted my idle and I was fine.
Old Apr 21, 2012 | 07:13 AM
Nevermind, your rpms are normal mine idles at 750 bc my chip in my ecu is set to idle at that, thats normal. Mine idles around that maybe about 50 to 100 more rpms.
Old Apr 21, 2012 | 08:58 AM
jakescakesz06's Avatar
mines idles low and I have checked the fitv and iacv as well. It idles from 500 then drops to 200.
DO/\/\O
14
May 9, 2011 05:56 PM
Ransom
Sep 11, 2006 11:15 AM
EK Josh
29
Apr 11, 2005 11:05 AM
