axle to half shaft wobble
Old Apr 20, 2012 | 05:43 AM
rotaryjunky's Avatar
Default axle to half shaft wobble
I have a 93 hatch with a jdm ITR engine and tranny. I don't know what half shaft it has, but my driver side axle started clicking so I replaced it with a 98 integra axle. It seems to fit and clicks into place but then wobbles just enough to be noisy. The noise is worse when turning right. The half shaft spines look ok but have flat edges and I can't remember if that is normal. Should I buy a new half shaft and axle and start over or is there something I am missing?
Old Apr 20, 2012 | 07:57 AM
94EG8's Avatar
Seagull Management
Default Re: axle to half shaft wobble
It's probably just a bad axle. Autozone replacements are notorious for vibration issues.
Old Apr 20, 2012 | 08:30 AM
beecee18's Avatar
F@%K AUTOZONE!!!!
Last edited by Libertariat; Apr 20, 2012 at 08:50 AM. Reason: Watch the racial slurs.
Old Apr 20, 2012 | 09:09 AM
Should I make them replace it or should I find one somewhere else?
Old Apr 20, 2012 | 09:19 AM
sstupid's Avatar
10 Year Member
Wobble in the hub or wobble in the tranny? Could be a bad input shaft bearing in the tranny.
Old Apr 20, 2012 | 10:15 AM
Half shaft is solid, at least in the tranny. The axle wobbles on the half shaft.
Old Apr 20, 2012 | 10:20 AM
94EG8's Avatar
Seagull Management
They will exchange it, but you might want to just return it and buy one elsewhere.
darot
Jul 18, 2009 01:13 PM
IT GUY
Aug 29, 2007 10:47 AM
fu*kfaceC1EH2
Sep 12, 2003 09:13 AM
fu*kfaceC1EH2
Sep 11, 2003 01:22 AM
