I think I am burning oil...
Old Oct 12, 2002 | 12:02 AM
TurBoXBirD16's Avatar
Default I think I am burning oil...
My oil level seems to be dropping in a period of time..
it ususally goes down faster if i boost more.. i think...
but i haven't seen any white smoke coming out of my exhaust..
maybe it only happens when i boost??
plz help
and tell me what to do to check...
does it sound like it's the rings??
i checked my compression not too long ago, it was all good
help plz
thanks
Old Oct 12, 2002 | 03:01 AM
Cyber ITR's Avatar
Default Re: I think I am burning oil... (xbird)
u can have good compression with fucked up oil rings
Old Oct 12, 2002 | 06:19 AM
pelotudo's Avatar
Welcome to the dark side. Before boost=no burning, after boost=3/4 of a quart between changes now.
The more you boost, the more you will burn. You have a whole new turbine there now, and that thing is heating the hell out of the oil burning it. Check your rings though. If you're not getting any smoke, and it's not a significant amount between chanes, I wouldn't worry too much.
jB
Old Oct 12, 2002 | 06:20 AM
pelotudo's Avatar
jB
[EDIT]
Do you have any leaks in your feed/return lines? I had a tiny one when I first started boosting, and it scared the sh*t out of me seeing my oil level drop that fast. Got under the car, and found my feed line the culprit.
Old Oct 12, 2002 | 08:28 AM
tygsr's Avatar
Default Re: I think I am burning oil... (PelowisheshewascoolTudo)
Turbo cars burn oil. Simple as that.
Old Oct 12, 2002 | 09:06 AM
metal-x's Avatar
Default Re: I think I am burning oil... (tygsr)
yeah I have a jrsc and I noticed if I boost alot in a period of time bye bye oil...
Old Oct 12, 2002 | 10:52 AM
Default Re: I think I am burning oil... (metal-x)
ok..
so i should do a leak down test just to make sure the rings are fine, right??
thanks guys
i am alot happier now !
so-cal-em1
May 9, 2007 11:38 AM
!hybrid
May 25, 2006 05:55 AM
tyflip2
Aug 24, 2004 06:57 PM
1996GsrVtec
Apr 15, 2002 08:07 PM
