my car doesnt start
i have a 93 honda delso si 1.6. and i recently painted it without grounding it or dissconnecting the batterie. i replaced the spark plugs and the ecu thinking that would solve the problem. when i turn the key the fule pump doent prime but thats because theres no current running through the wires so i jumped the fule pump to get fule to the engine. but as i jump the pump and try to turne on the car all it does is crank but dosent start. i checked the fuses and there ok and also checked the main relay. any other ideas on wat this issue could be?
wanna_run
25
Feb 7, 2012 09:11 AM
