Carbon fiber:wet to dry
Old Apr 19, 2012 | 07:54 PM
tstchatch's Avatar
Icon6 Carbon fiber:wet to dry
What would have to be done to make a wet carbon peice have that dry look? Wet sand, dry sand etc? And would it affect the strength and quality of the carbon itself?
Old Apr 20, 2012 | 10:09 AM
tstchatch's Avatar
Default Re: Carbon fiber:wet to dry
Anyone?
Old Apr 20, 2012 | 10:33 AM
shocker911's Avatar
you can use a flat clear to make it look flat
Old Apr 20, 2012 | 12:20 PM
EH2Kevin's Avatar
He is referring to changing the look of the carbon fiber from the first picture to the second picture.
Old Apr 20, 2012 | 12:46 PM
Hawkze_2.3's Avatar
Just wet sand it. If you don't hit the fibers, you won't affect the strength.
Old Apr 20, 2012 | 12:47 PM
Hawkze_2.3's Avatar
From carbon fiber to Kevlar?
Old Apr 20, 2012 | 12:49 PM
VRD^don's Avatar
LOL
Old Apr 20, 2012 | 01:31 PM
tstchatch's Avatar
what grade of sand paper would you guys say is best suitable? 800 up to 2000? im afraid to leave little scratches if i go too coarse.
Kustom X's Avatar
I would do what shocker911 said. scuff, clean, flat clear.
Old Apr 20, 2012 | 01:32 PM
Kustom X's Avatar
grey scotchbrite pad
Old Apr 20, 2012 | 01:37 PM
FijiBlueFG2's Avatar
Road House
i lold.
Old Apr 20, 2012 | 01:39 PM
EH2Kevin's Avatar
Yes. I know what it is called. I was just clarifying for the other poster.
Old Apr 20, 2012 | 01:45 PM
tstchatch's Avatar
grey scothbrite and wet sand. got it. and direction i should go? across the hood from left to right or from front to back?
Old Apr 20, 2012 | 01:54 PM
Road House
He's asking about dry carbon fiber, like this...
Kevlar is an entirely different material.
Old Apr 20, 2012 | 03:20 PM
EH2Kevin's Avatar
Thank you for the picture! I guess I was the confused one.
Old Apr 20, 2012 | 07:39 PM
Kustom X's Avatar
Grey scotchbrite and you can use a scuffing paste from a auto paint store. use it wet and it will clean and scuff at the same time and help adhesion. when you scuff keep moving in a circular motion dont just scuff the same spot over and over. and keep your finger together and use more of your palm. you dont need to wet sand. after scuffing rinse with water. then use a water based cleaner like rapid prep and a blue shop towel. make sure its completely clean use a tack rag to remove any lint. do not press to hard with the tack rag. then fill paint gun do a quick blow off with the air then clear.
Old Apr 21, 2012 | 07:54 PM
tstchatch's Avatar
A matte clear I'm assuming?
Old Apr 22, 2012 | 08:03 AM
Kustom X's Avatar
you know what a bitchin clear is, Alsa soft feel clear. Take a look
http://alsacorp.com/products/softtouch/softtouch.htm
Old Apr 25, 2012 | 07:03 AM
tstchatch's Avatar
what exactly should i be looking at? the resins?
jdmfamilia
Sep 17, 2011 09:40 AM
Shizznaz
Feb 11, 2005 09:24 PM
Arsenal
Sep 9, 2002 03:32 PM
