Yet another O2 primary sensor problem
Old Oct 11, 2002 | 11:44 PM
Mr.Rab's Avatar
Default Yet another O2 primary sensor problem
I installed a Comptech header today and ran into some problems with the whole primary o2 sensor. As you can see from the picture the connecting wires disconnect from the connecting unit. I had no choice to do this due to the amount of torque placed on the bolt connenting o2 sensor to the header unit.
So if anyone can please tell me a simple way of getting these damn wires back in the connector unit snug.
For the whole story click this link. https://honda-tech.com/zerothread?id=304827
Old Oct 12, 2002 | 04:17 PM
Mr.Rab's Avatar
Default Re: Yet another O2 primary sensor problem (Dr. RAB01GSR)
ttt and yeah no one has a ******* clue. It's a hard problem I think Acura will have to take care of it.
Old Oct 12, 2002 | 05:48 PM
BreakStuff's Avatar
New User
Usually it just takes a little push on the wire terminal to "lock" it within the connector..
if the terminals were accidentally pulled out, the the lock tabs in the connector may have broken off causing the terminals to come out of the connector easily...
You may want to try using an epoxy to hold the terminals in the connector, or maybe you can do away with both connectors and just "hard wire" the terminals together...
Old Oct 12, 2002 | 05:57 PM
Mr.Rab's Avatar
Default Re: Yet another O2 primary sensor problem (BreakStuff)
wow I'm a idiot, I never thought of that, but I think I already got the wires mixed up. Do you have a solution to this. I need a helms
Old Oct 12, 2002 | 06:06 PM
BreakStuff's Avatar
New User
I think it would be safe to experiment here and just connect the wires together... If you get the wires crossed it will affect air/fuel mix and make the car idle like crap and eventually throw a CEL... just reverse the 2 wires if that happens.. I'm assuming this is a non-heated 02? If this is a heated 02 I would disregard everything I just said since there is alot more wires involved...
Old Oct 12, 2002 | 06:30 PM
sleeprhatch's Avatar
i agree with above but it is not a heated o2 it would have 4 wires
Old Oct 12, 2002 | 06:31 PM
Mr.Rab's Avatar
Oh ****, very interesting you said this, because I've notice some Idle problems when I'm stopped at the stop light. It will go down to 500 rpms and almost go below until I hit the gas. Would you recommend me just disconnecting the wires, mess around with them until find the right setting, go to the Acura dealership asap with the wires disconnected. It's the o2 sensor that is attached to the header.
Old Oct 12, 2002 | 06:33 PM
Mr.Rab's Avatar
Default Re: Yet another O2 primary sensor problem (sleeprhatch)
It has 4 wires. So I think all I need to know is what wires go into what connectors.
Old Oct 12, 2002 | 06:43 PM
BreakStuff's Avatar
New User
4 wires = heated 02 sensor... don't experiment and find schematics...
Old Oct 12, 2002 | 07:14 PM
Mr.Rab's Avatar
Ok few questions and BreakStuff I owe big time.
1. Shall I keep driving the with the O2 sensor still plugged in and not sure if they are in the correct connections.
2. My brother has a Helms manual and they sorta give you the color code of what color wires go into what connectors. Shall I relly on this info, BTW helms manual for a 1997-1998 prelude.
3. Call my buddy and use his 94-97 integra helms manual. Do you think that he has the heated O2 sensor in his header pipe?
Shay Cothran
May 28, 2015 04:33 PM
tuname420
Engine Management and Tuning
Sep 15, 2008 12:37 AM
stevenskates
Jan 8, 2008 01:14 AM
legends
Feb 18, 2007 06:24 PM
Themouse
19
Feb 1, 2006 04:17 PM
