Timeings jumping helpppppp
Old Apr 19, 2012 | 06:32 PM
1997boostedeg's Avatar
Default Timeings jumping helpppppp
Ok I have a d16y8 that is fully vatar built boosted on 15 pound and I set it at TDC and the crank lines up and the fireing order is correct and the conection points for the cap are correct on the distribuater and when I go to start the car it just cranks but the timeing jumps every time why does it do this?????
Old Apr 19, 2012 | 06:38 PM
crawfo661's Avatar
Default Re: Timeings jumping helpppppp
It wont start and then you re-check time and its not where you set it? Do you have the right size timing belt on it? Thats the only reason i can think of that mechanical timing would change unless your timing belt tensioner is junk and you are actually skipping teeth. Has your valves smacked your pistons yet?
Jdbdkid93
15
Jan 25, 2021 05:20 PM
ddn1313
Aug 4, 2018 02:46 PM
boomersz
Mar 4, 2007 09:09 AM
specv5150
11
Oct 7, 2004 02:39 PM
hon
Jul 23, 2004 03:49 AM
