What to check for this problem ?!?!?!!.
Old Apr 19, 2012 | 04:02 PM
Bert01's Avatar
Icon2 What to check for this problem ?!?!?!!.
sunroof dont work and head lights middle bulb dont work?!? . What should i check??. -THINGS I DID..new fuses and relays ..i put on a new hatch but no wires are out ..help please THANK YOU
Old Apr 19, 2012 | 06:10 PM
neophish's Avatar
Default Re: What to check for this problem ?!?!?!!.
what kind of car do you have? and did you replace the entire rear hatch? if so make sure all of those rear lights wires aren't messed up, and also wired the same to be compatible with your car.
and did the sunroof and light problem happen at the same time? check grounds/wires ect.
Old Apr 23, 2012 | 03:16 PM
Bert01's Avatar
its a 91 honda civic hatch si the back hatch came from a 89 or 90 no sure dx hatch back ? .. and i got the lights working now the thing is i close my door theres no power to the car and the hood gives no power to the car wen closed .. wat is this ?.. i heard some were its not grounding but were .. i change the alternator and radiator i double check if not wat shoould i go back and look for ?.
Old Apr 24, 2012 | 12:24 AM
ef4real's Avatar
hood gives no power?? could be grounding problem
tommy boy2
Feb 20, 2019 02:22 PM
219DAdriver
Feb 7, 2008 11:22 AM
teal_dx
Dec 2, 2007 09:28 AM
B SERIES US
Dec 11, 2004 06:19 AM
