b16a2. obd2 to obd1 help
Old Apr 19, 2012 | 12:01 PM
ev94eg's Avatar
Default b16a2. obd2 to obd1 help
Ok so I'm about to do my first swap in my 92 cx hatch. I got a b16a2 and the guy gave me a obd2a gsr harness could I use that harness and plug in to the main harness( which is obd1) or could I use my obd1 harness that's in my car already and just splice injector wires and alternator plug into the obd2 injector clips.
Old Apr 19, 2012 | 12:49 PM
beecee18's Avatar
Default Re: b16a2. obd2 to obd1 help
This subject is Sticky food.....
Just search around a take a little time to research swap guides and it will tell you all, For your one question NO that harness will not plug and play for your application
Old Apr 24, 2012 | 02:27 PM
ev94eg's Avatar
preciate it man. i been busy getting the d series out of my car when i find time. im just going to use my obd1 harness and splice the injector wires and alt plug.
ive been reading where some people say yuou have to re pin the distrib. and some people say you dont have to
Old Apr 24, 2012 | 02:57 PM
chewyv's Avatar
pm4nudes
+1 interested. Ask them how they plugged the obd2b plug into the obd1 plugs. I would like to know this info. If they say jumper harness...waste of money...
Old Apr 24, 2012 | 06:42 PM
beecee18's Avatar
depends on what is with the motor,
obd1 or obd2
Theres just so many ways of going anout it depending on what you guys have to work with.
Old Apr 24, 2012 | 07:40 PM
ef4real's Avatar
If its your first swap i think try to get the vtec obd1 dizzy. You should be able to sell the OBD2 dizzy. Then make your vtec sub harness with pins from the junkyard/parts car. Jusy my .02
Old Apr 24, 2012 | 08:36 PM
Nickeg9Ej1's Avatar
I'd use the obd2a gsr harness, get a obd2a gsr dizzy, wont have to change much else really being a 92 its already wired for vtec, only thing you may have to change is 1 wire to 4 wire O2 that's all i can think of right now
Old Apr 25, 2012 | 01:40 AM
HondaPartsHero's Avatar
Technical Hero
^this. The O2 will have all the wires on the GSR harness and all the other wires are already there for the 02. Youll need to wire up knock sensor and the IABs for the intake from the sensors to the ECU.
Old Apr 25, 2012 | 10:58 AM
Arthas's Avatar
Can OP use a wire harness from a 92-95 Ex and wire it up with a chipped P28 running a B16A2 map?
Old Apr 25, 2012 | 11:00 AM
Fliptard's Avatar
Just use obd1 injectors, get a drizzy jumper harness and get an obd1 alt, either an obd1 b16 ecu or a chipped P28. No cutting or splicing. Just plug in and go
Old Apr 25, 2012 | 11:01 AM
Fliptard's Avatar
Oh, and get an EX wire harness for a 92-95.
Old Apr 25, 2012 | 11:18 AM
beecee18's Avatar
yup
Old Apr 25, 2012 | 11:19 AM
beecee18's Avatar
yup
just use the above pinout to wire the knock, sensor to ecu and
Old Apr 25, 2012 | 02:45 PM
DelSol-B18's Avatar
I'm doing this swap in my 93 sol. Use your same wire harness. Get an obd1 dizzy. Wire you harness for vtec then get a p28 ecu chipped to run a b16a2
Old Apr 25, 2012 | 10:49 PM
ev94eg's Avatar
that or get a p30 ecu lol
Alex Preece
Oct 24, 2018 10:31 PM
appelsos
11
Jul 11, 2011 06:24 PM
Cuda
Jan 16, 2008 06:18 AM
gezer
Aug 26, 2004 10:42 PM
